Replica 2011-2012 LED headlights (Alibaba)
#136
Debating on buying these and just replacing each LED with a better one if they go out. What do you guys think? Is it worth the $374? And are they just a plug and play?
http://www.ebay.com/itm/2006-2009-Le...717398&vxp=mtr
#137
#138
Just finished installing with also a 6k HID kit and all works well.
Initial impressions - Like another member said, the leds are just like the new accord's leds. The projectors are not bad by any means, and the cutoff line is VERY VERY sharp. Much better than the OEM non-hid projects IMO. Fitment is a 8/10, and could use some adjusting. Overall well worth the $400. I wouldnt pay any more than that though.
Pics tomorrow since my camera is charging.
Was converting to HID plug and play also or did you have to mess with the wiring harness?
#139
The headlights also comes with resistors that are plug and play to prevent hyperblinking
#140
Its plug and play. The wire that is attached to the halogen bulb will connect to the (+) on your HID kit. The negative is currently grounded against the projector shroud, so you will have to disconnect and connect it to the (-) on your HID. Its self explanatory once you look at it.
"thank you for your interest in our products. These lights are essentially all plug and play, this means that the low beam and high beam will work just by plugging in the wiring harness. The only wiring that needs to be done is for the daytime running lights, you can tap the DRL wiring into either the low beam wire to have the light constantly on or you can tap the wire into your existing parking lights to have them switch on when the parking lights are on.. If you watch the second video on the ad, it will show you what you need to do for installation. If you are unsure on how to install these, we highly recommend professional installation. This will make sure that you and your car are safe. Thank you."
#141
The headlights do have an extra harness that i couldnt find a use for (looked like a 4 pin connector). knbnugyen and others, do you know what this is for?
#142
But if you do that 2nd click don't the taillights turn on like they would if your headlights were on?
