Help from IS owners with 19s
word!
The rears won't be just flush with the fenders, it will stick out past the fenders a bit and would probably require rolling if you are dropped too low.
I have 19x9.5 and 40mm offset in the rear, this setup doesn't rub and just sit flush enough without rubbing. I'm even running 275 rears and dropped one inch.
I'm running 19x10 +38 with 275/30 19 ZR michelin Pilot Super Sports dropped on BC/BR coilovers and if I go to low they will rub. I put some negative camber in and raised it a little and no problems now. The fronts are 19x8.5 + 32 235/35 ZRs and they will also rub if I go to low, I put some neg camber into the front and raised it a little more and only have a little inner fender liner rub now that a heat gun will fix.
thanks for all your input cant wait to throw them on
word!
sticking out a bit would be ok and yes would get fenders rolled but im shooting for a flush mount we'll see next friday when I try them on
I dont think I would do any camber, but if need be can it be done on stock suspension? and how much angle?
word!
mrrhr4
06-09-15 09:01 PM
lexus316
03-18-12 06:30 PM
