OEM HID flickers and completely turns off
Old 11-28-13, 07:18 PM
smokyis350
smokyis350's Avatar
Default OEM HID flickers and completely turns off
Was changing out my city lights and while I was testing the lights my OEM low beams goes out. First it flickers and then completely shuts off. There was a light burning smell electrical smell. Is this the HID ballast, bulbs, or the wiring problem?
Old 11-28-13, 07:26 PM
NickawdIs
NickawdIs's Avatar
yes same thing happen to me. Usually when i hit a bump because my car is lowered .
Old 11-28-13, 07:32 PM
Cali2is
Cali2is's Avatar
For me it was the bulb. But I have heard of ballast issues as well. switch the bulbs to find out.
Old 11-28-13, 08:56 PM
predacon47
predacon47's Avatar
Originally Posted by Cali2is
For me it was the bulb. But I have heard of ballast issues as we'll. switch the bulbs to find out.
Same with me, it was the bulb.
Old 11-28-13, 08:58 PM
panda08
panda08's Avatar
the HIDS can turn a purplish color too as a sign theyre going out
Old 11-28-13, 10:07 PM
smokyis350
smokyis350's Avatar
Seems like this is a common problem. Did you guys end up getting a replacement bulb or just went with a whole new set of aftermarket bulbs?
Old 11-29-13, 01:31 AM
predacon47
predacon47's Avatar
I went with Phillips 5000k and love them. If these go out then I'm going with 6000k either one are way better than the OE in my opinion.
Old 11-29-13, 11:11 AM
smokyis350
smokyis350's Avatar
How much did that run you?
Old 11-29-13, 12:50 PM
asuraIS250
asuraIS250's Avatar
I had the same thing happened to me not too long ago, it turned out to be the bulb, did some investigating into the issue n come to find out it was the wrong watt his bulb that the previous owner put in, so make sure if you're going to get aftermarket hid bulbs make sure they are 35watts n not 55 watts. 55watt hid bulbs will end up melting ur d4s connector which is probably why you smelled something burning Smokyis350
Old 11-29-13, 03:50 PM
predacon47
predacon47's Avatar
I lucked out and got a brand new set from a another member for $60.
Old 11-29-13, 04:31 PM
smokyis350
smokyis350's Avatar
Good to know. But I am using stock HID and ballast.
I might just grab some Garax 6000k D4s bulbs for $90.
Old 11-30-13, 12:19 PM
asuraIS250
asuraIS250's Avatar
those are very reputable along with Phillips from what I've been told
Old 11-30-13, 12:54 PM
MrKayVu
MrKayVu's Avatar
My OEM low beams just went out yesterday, but it was only the passenger side. Every other lights work so could that also be that my bulb went out too?
Old 11-30-13, 04:40 PM
predacon47
predacon47's Avatar
Try taking the drivers bulb out and test your passenger side. Hopefully it will narrow it down to just the bulb and not the ballast.
Old 11-30-13, 05:09 PM
smokyis350
smokyis350's Avatar
Seems like it is the bulb. My passenger side went out also.
I just grabbed some Garax 6k for $90 shipped. Didn't want to replace one and the color is a bit off.
Quick Reply: OEM HID flickers and completely turns off
