downshifting with paddle shifters
Old 11-20-13, 01:01 PM
2012IS250
2012IS250's Avatar
Originally Posted by nabbun
it'll jerk if your foot is off the accelerator pedal while downshifting. this car doesn't have rev match so it won't blip the throttle to match unless you have your foot on the pedal. I've only used the paddle shifts for showing off my intake or as a gear limiter.
Yeah I just blip the throttle, I'm more used to doing that (did it all the time in my mustang in the past). Isn't hitting the rev limiter bad for the car though? I've heard people bounce of it a lot when they're drifting
Old 11-20-13, 01:02 PM
2012IS250
2012IS250's Avatar
Originally Posted by redspencer
Here's the thread for the IS300 LSD swap into an IS250:
https://www.clublexus.com/forums/is-...-my-is250.html
Definitely talk to CL member Jeff Lange if you have questions on that swap.
Thanks I will definitely message him.
Old 11-20-13, 01:46 PM
g2bme
g2bme's Avatar
Originally Posted by 2012IS250
changing the gauges to show gears actually did help but I realized that if I revved just enough and timed it correctly while the transmission is shifting into the lower gear, it prevents the jolt completely. I asked my sister (she was with me in the car at the time) if she felt anything while I was downshifting and she said she didn't
what do you mean show the gears on the gauges? Whenever you put it into the "shift" mode the gear will show you right in the middle of the gauge. Correct me if I'm wrong, but the paddle shifters only come into play when in this mode?
Old 11-20-13, 01:55 PM
2012IS250
2012IS250's Avatar
You have to press the DISP button on the steering wheel, it's the last option on the LCD screen before it goes back to showing the outside temperature.
Old 11-20-13, 02:00 PM
nabbun
nabbun's Avatar
I don't always hit the limiter. But, when I do, I 4 wheel drift
lol all kidding aside, I don't let the needle hit the limiter. When I used the manual mode for gear limiting, It's because I don't want it to upshift into a higher gear when it's not needed. For example, I used it a lot at the Tail of the Dragon. There were a few straights and I didn't want the car to go into 4th or higher when I let off the throttle so I left the shifter in 3rd. In the hairpins, I shifted down to 1 and back up to 2 or 3 so I'm always in the meat of my powerband.
Old 11-20-13, 02:09 PM
2012IS250
2012IS250's Avatar
Yeah same here, I do the same on highway 9, we got about 2-3 hairpins and a bunch of 90 degree angle turns so I always keep the car in its power band.
Old 11-20-13, 02:15 PM
kickin8
2IS/2RX/4RX
kickin8's Avatar
IMHO it's pointless to get a LSD on an AUTO IS250.....
Old 11-20-13, 02:35 PM
2012IS250
2012IS250's Avatar
I can see why you said that but I seriously can't make my back end kick out on wet ground and maintain it with an open diff
BIGVIC23
01-20-19 05:25 PM
Mosh
ES - 5th Gen (2007-2012)
17
09-27-06 12:41 PM
LTunedGS3
Maintenance
05-11-06 08:14 PM
winsalem
08-26-05 12:12 PM
Quick Reply: downshifting with paddle shifters
