called tire rack does this sound right?
Just bought an 06 is350 and it came w an extra set of blizzak tires.225/40/18 and 235/40/18 so stepped down from the stock 255/40/18. When I went to order the 235's he claimed I may have traction control issues due to the smaller size.. does this sound right? Want to be sure before I order as I would prefer the smaller size for winter. Also noticed more inner wear on the tires as well but they are worn through just more on the inside..
Inner is pretty common on these car up front search and you find solution on that. If your doing it for winter the narrow the tire the better the traction. I run 225-45-18 for the past 3 winter not one issues. Since your is an 06 learn the pedal dance to turn traction/vsc off during winter driving.
You will see, I would just advise knowing how to disable the trac system.
Because it can prevent you from moving at all lol. For instance lets say you need to back out of a parking spot you might not be able to. But with the systems offline you can spin the tires a bit and wiggle out of the spot.
btw, I have 225/40/18 all around on my car.
Update:
I stopped by the dealership to book my cam gear fix and asked about 235's on the rear and they told me not to do it, too much stretch and too much of a drop from 255.. the tires I have are worn all across but definitely more worn on either the inside or outside (I can't remember off hand) so maybe that is attributed to stretching the smaller tire over time? Just passing on some info I got take it fwiw
Update:
tmf3lehigh
11-24-06 07:19 PM
