Why is this light on?
That sign indicates Tyre Pressure issue, check your tyres. If all the pressure is fine, could be a faulty TPMS sensor.
I had a similar issue except mine was leaking air so I got one for free from a guy I know and I went to Americas Tire to reprogram it to my car. Well first you want to find out which one it is and buy just one or you can get a set of 4, you can either get them from the dealer or here in the classifieds section people sell them a lot. If you get a used one then a tire shop should be able to program them for free.
If I remember correctly if a tire is low the message displayed is something along the lines of "check tire pressure". This one indicates issues with getting a reading from tire pressure sensor(s). Is it possible that you switched the settings to the 2nd set of sensors. If not, it sounds like a faulty sensor.
You have low Tire pressure. Check "ALL" of your tires, your 4 tires + the spare in your trunk cause that has the TPMS too. to know the proper PSI to put in check the sticker on your driver side door frame.
Tire pressure...keep up with it.
