help ! is250 awd
It will work if you want to blow your rear differential. Never run different size tires on an AWD.
If you're going to run staggered sizes, you have to make sure the rolling diameter is the same (front to back). The sizes you guys described will not work without causing damage to your vehicles.
@LexusIS954: I really hope your car is not AWD for your sake.
It will work if you want to blow your rear differential. Never run different size tires on an AWD. If you're going to run staggered sizes, you have to make sure the rolling diameter is the same (front to back). The sizes you guys described will not work without causing damage to your vehicles. @LexusIS954: I really hope your car is not AWD for your sake.
Also search, there's a thread dedicated to this.
