Non-staggered set up with RWD
Hello,
I own a 2009 IS250 RWD with 6 speed manual. I'm getting to the point were I'm going to need new tires. I dislike the fact with the staggered set up I have no rotation options.
My question is can I go down in tire width so I can rotate tires to opposite corners to extend the life of my tires.
I have the factory 17" rims.
Any help would be greatly appreciated,
Chris
Chris
@aw04lfan,
I wonder if there is a difference in rims between Canadian and US models as I have been told that the rear rims are wider with a different offset. Can any one confirm or deny this?
thanks once again,
Chris
thanks once again,
Chris
Keeping it Real
Factory 2IS RWD sizes:
16x7.0" +45mm all around with 205/55R16 (IS250 only, not used in USA, used in Canada for 2006-2010 only)
17x8.0" +45mm all around with 225/45R17 front and 245/45R17 rear (IS250 and IS350)
18x8.0" +45mm front and 18x8.5" +50mm rear with 225/40R18 front and 255/40R18 rear (IS250 and IS350)
I am running 17x8.0" all around with 245/40R17 all around on my RWD IS250 without issue. I enjoy being able to rotate the tires and I like the neutral handling of the car with the square setup. The ECU/programming seems to be the same between cars with the staggered and non-staggered setup. I don't know if Lexus just ignores the difference in rolling diameter or compensates when it detects all 4 wheels spinning at the same RPM for a certain distance, but I haven't noticed any inaccuracy in my speedometer/odometer with the shorter rear tires.
Jeff
Jeff
