Loctite double sided tape for rear spoiler
Old 09-25-13, 11:04 AM
sens
sens's Avatar
Default Loctite double sided tape for rear spoiler
I bought a rear trunk spoiler off ebay for $88 a month ago from Taiwan and I have been using 3m double sided tape from office max. Throughout the month, I have retaped the spoiler twice because it started to become loose after two weeks. I clean both surfaces with soap and rubbing alcohol before taping the spoiler. I also tried the 3m tape from O'reilly auto part but the stickyness of the tape was no where near as sticky as the one from office max. I searched through this forum and read some good things about loctite tape and I want to ask if it will damage the paint on the car. Also any insight of what I'm doing wrong with just 3m tape is appreciated.
Thanks
Old 09-25-13, 11:08 AM
Gr33nHrn3t
Gr33nHrn3t's Avatar
Adhesion promoter will be your best friend...
http://www.findtape.com/product605/3...pplicator.aspx
Apply the promoter as the final step before putting the spoiler on. Wait for a minute or two to let it dry.
Old 09-25-13, 11:11 AM
Joeb427
Joeb427's Avatar
and this...
3M VHB Heavy Duty Mounting Tape 5952 Black, 3/4 in x 15 yd 45 mil: Amazon.com: Industrial & Scientific 3M VHB Heavy Duty Mounting Tape 5952 Black, 3/4 in x 15 yd 45 mil: Amazon.com: Industrial & Scientific
Old 09-25-13, 11:15 AM
kickin8
2IS/2RX/4RX
kickin8's Avatar
you will need automotive grade double sided tape....
Old 09-25-13, 11:24 AM
sens
sens's Avatar
Will the adhesion promoter damage the paint? When the package arrived, it came with adhesion promoter. Not exactly the same as the link you shown.
Old 09-25-13, 12:39 PM
Gr33nHrn3t
Gr33nHrn3t's Avatar
Adhesion promoter should not harm the paint/clear provided it is fully cured.
Old 09-25-13, 12:53 PM
tenaciousF
tenaciousF's Avatar
The promoter does work wonders but you may only get one shot at placement because the bond is so strong. I used a series of small cardboard shims to peel then drop, peel then drop the spoiler into place. Then I peeled and pressed the vertical part in place. You can peel back and over about an inch on the ends of the tape to have a place to pull or even split the backing to have a grip in the middle.
xcorpion47
12-30-15 05:16 PM
FUZCO
RC - 1st Gen (2015-present)
07-22-15 09:02 AM
mike51O
07-30-11 11:12 PM
sepukku
09-25-08 04:40 PM
delmo
GX - 1st Gen (2003-2009)
02-09-04 09:49 AM
Quick Reply: Loctite double sided tape for rear spoiler
