220d head gasket
Old 08-02-13, 12:03 PM
crazydrive
crazydrive's Avatar
Default 220d head gasket
Hi does any one know, to replace the head gasket on a 2006 is220d does the engine have to be removed thanks
Kodiak303 (09-03-23)
Old 08-02-13, 12:08 PM
Gville350
Gville350's Avatar
To answer your quesion..no, it would not have to be completely removed from the engine bay.
What makes you think you have a bad HG?
Old 08-03-13, 09:32 PM
panda08
panda08's Avatar
Don't have to take the engine out of the car completely, but the block does have to be dismantled.
Old 08-04-13, 11:58 AM
Gville350
Gville350's Avatar
^I've not ever had to pull a motor out of a Lexus before, not I'd image that IF you only have a bad HG you would ONLY need to remove the head(s) and the front timing accessories. What do you mean by "the block does have to be dismantled?" The block usually refers to ONLY the portion of the engine containing the crankshaft/pistons/rods/etc...not the heads.
Sorry to be technical, but you sorta have to with motors.
Old 08-04-13, 01:05 PM
crazydrive
crazydrive's Avatar
Hi thanks for replys , engines over heating, blowing water out of header tank, cooling system pressure tested OK, no visible signs of leaks.
Tried removing the front timing casing to remove chain. but sump is bolted and bonded to bottom of casing, in order to remove sump the front sub frame and steering rack looks like it would have to be removed which looks like a big job , was thinking maybe it would have been easier to remove engine.
Just wonder if anyone out there had done job before and could shed some light on it thanks
Old 03-23-21, 01:19 AM
Zxcv35
Zxcv35's Avatar
Default Remove timing cover
I am trying to remove timing cover do I have to remove oil sump as cover is not moving
Old 03-23-21, 04:00 PM
MikeFig82
MikeFig82's Avatar
You can find help here. Dedicated to the 220D.
https://www.lexusownersclub.co.uk/fo...-is-200d-club/
PseudoK
Performance & Maintenance
10-14-23 10:41 AM
Stilkus
12-02-18 01:00 AM
tanakamike
SC- 1st Gen (1992-2000)
12-18-15 12:07 PM
speedrace
04-25-08 12:32 AM
jewelerz
08-04-02 03:19 AM
Quick Reply: 220d head gasket
