Could an IS350 handle 100LL AvGas?
Old 07-14-13, 04:05 PM
GaaraOTS
GaaraOTS's Avatar
Talking Could an IS350 handle 100LL AvGas?
see title.
Old 07-14-13, 04:09 PM
bob4256
bob4256's Avatar
Did a quick google search.....is that airplane fuel??
Old 07-14-13, 04:38 PM
magnuscat
magnuscat's Avatar
Yes, it is. Used in recip engined aircraft.
I wouldn't use 100LL, especially in a high compression, direct injection engine. Pressures and heat are already considerable in those. 100LL runs pretty hot. Aircraft engines are typically low compression. When I was a pilot and was constantly around airports I used to fill up my bikes and old mustangs with 100LL. One of my bikes designed to be run on leaded gas would have a small gasket leak anytime I used unleaded. When it had avgas in it, it wouldn't have the leak at all. Just as engines that were designed to use leaded gas started having problems with unleaded fuels, mainly valve seating problems, the engines designed to have unleaded fuel could have problems using low lead.
They now have to design engines not only to run on unleaded gas, but it is absolute crap. Ethanol mixtures determined by regional and state laws has only made gas worse over the years. Ethanol is a horrible product which turns foamy and nasty in a car. Left in a tank it will accumulate water and ruin old metal tanks. It gunks injectors and decreases fuel efficiency. feel good naer- do- wells think they are doing good for the environment, but in reality the offset of decreased efficiency thus increase in fuel consumption only increases pollutants in the end. End of rant.
Old 07-14-13, 05:06 PM
genaos11
genaos11's Avatar
U should try it .....let us knw what happen
Old 07-14-13, 05:26 PM
GaaraOTS
GaaraOTS's Avatar
Not with my car... you first :P
Old 07-14-13, 05:28 PM
GaaraOTS
GaaraOTS's Avatar
Well I'm just curious, I know some people run 100 octane UL racing fuel and was wondering if it would have problems with leaded fuel or not. I run 100LL in my 1960 Chrysler Windsor because it was made for leaded, but I wouldn't try it in a UL engine without doing some research first.
Old 07-14-13, 07:03 PM
GaaraOTS
GaaraOTS's Avatar
This is a useful thread:
http://www.ffcars.com/forums/17-fact...cing-fuel.html
Old 07-14-13, 07:18 PM
magnuscat
magnuscat's Avatar
Originally Posted by GaaraOTS
That seems to sum it up nicely. 100 unleaded would be a waste and 100LL would not only be a waste, but it would cause additional fouling especially in a high compression direct injection engine most especially when they already have carbon issues.
As a side note those of us who ran the old 60's muscle cars designed for leaded fuel after they made the switch used to use a product called marvel mystery oil. I have no idea if it is still made, but I would imagine it is. We mixed a cap of it into each gallon pumped and it would lubricate the valves and keep from having the seating problem. I used it in my old cars, old BMW and Harley bikes. You couldn't keep a harley from leaking oil, but at east you could keep the valves from sticking or leaking.
Old 07-15-13, 12:57 PM
Gville350
Gville350's Avatar
Definitely not on a 2IS,
Old 07-17-13, 09:23 PM
Mythotical
Mythotical's Avatar
Default Don't do it!
OH GOD NO!!! It may say low lead but let me tell you it has about 5 times the lead car gas used to have. in short it will kill your car even if you only use a little bit.
Old 07-18-13, 06:42 PM
SCWB
SCWB's Avatar
Your oxygen sensor and your catalytic conververtor will go bad quickly with Leaded fuel.
Old 07-18-13, 11:05 PM
Mythotical
Mythotical's Avatar
I happen to work around that stuff as I am a G.S.E. mechanic. The line service guys keep putting sump fuel 100LL in the tugs and other gas powered equipment ant it fowls the plugs really badly in short time. This one kid put about 2 gallons into a nearly full tank in his 91 Toyota pickup and plugged the cat in less than a day. Bad stuff for cats...
Old 07-19-13, 09:03 PM
GaaraOTS
GaaraOTS's Avatar
This. This is good input.
DaveGS4
01-09-23 03:31 PM
Shervin350
05-29-12 06:54 PM
j_version_
05-22-08 03:53 PM
silvervett
09-10-07 08:40 AM
erock901
03-04-06 05:15 PM
Quick Reply: Could an IS350 handle 100LL AvGas?
