Light help!!!
Old 06-27-13, 01:17 PM
sallydrive
sallydrive's Avatar
Exclamation Light help!!!
I've gone through 2 HID bulbs on me 07 250, both of them have weird looking beam patterns, the first one has a portion of the light shining on the ground about 10 feet long and 1 foot wide, and the second one has the same, but is much more dim but has lines through the pattern, like horizontal lines that are in the beam.. so weird! Please help, I don't think its the bulbs...what could be wrong!
Old 06-27-13, 08:32 PM
panda08
panda08's Avatar
are you installing these yourself? if so, make sure the bulb is seated against the projector fully and that the ballast wire is connected properly onto the bulb.
Old 06-27-13, 11:20 PM
whitebeast
whitebeast's Avatar
check your bulb type. Do you have HID headlight or halopgen one? wHAT hid kit did you have? We need more information to able to help you out
Old 06-28-13, 01:50 AM
sallydrive
sallydrive's Avatar
I purchased the Phillips OEM replacements D4S for the OEM HID's that came with the car, everything is factory, except for the bulbs of course.
Old 06-28-13, 05:34 AM
bob4256
bob4256's Avatar
Where did you buy the bulbs?
Old 06-28-13, 06:38 AM
whitebeast
whitebeast's Avatar
Be sure all the marks on the bulb is match with the housing. My guess is the bulb not seated properly.
Old 06-30-13, 03:58 AM
sallydrive
sallydrive's Avatar
I checked the seating, the bulb is in as far as it can go, but when i put both the clips in, the bulb still jiggles around a little bit, then when i put the ballast connecter back on in locks in and don't think it moves anymore. Maybe the clips are broken and don't hold them in anymore?
Old 06-30-13, 11:38 AM
whitebeast
whitebeast's Avatar
If the bulb seated correctly, they won't move at or. Are you sure you have correct bulbs? D2s look identical to d4s
conclevage
05-14-10 09:03 AM
pholt
02-22-09 10:44 AM
superpats
Lighting
02-01-06 03:30 PM
ummagawd
Lighting
01-26-04 12:24 AM
kapdori
08-02-02 07:28 PM
Quick Reply: Light help!!!
