2012 front bumper
2012 front bumper
I'm going to be installing a 2012 front bumper on my 2006 IS250. From what I can see so far, apparently the headlamp mounting brackets need to be changed. I have also got the LED headlamps which I believe the brackets can be cut and modified to fit. But if i'm going to be changing the bumper, will i need to actually get the new brackets or will the cut-out modified bracket work?
I am installing the 2012 bumper on the 2006 IS250. So you are saying that the existing plastic mounting bracket that sits below the headlamp can be used just by cutting it? I am also going to be installing the 2012 LED headlamps, but to install these i've read that people cut it to fit around the LED connector. So will cutting and customizing the original headlamp mounting brackets work for both the 2012 bumper and the 2012 LED headlamp?
Thanks
Thanks for your reply JasonChang,
Thanks
Thanks
