LED turn signals
Old 05-19-13, 06:14 PM
DanStrayer
DanStrayer's Avatar
Default LED turn signals
Hey Guys I'm Dan, I've been lurking on here a while but haven't introduced myself yet. I have an 06 is250 awd.
http://store.ijdmtoy.com/7440-Single...tm&click=35328
Is anyone using these? Could be a pretty cool look. I wonder if i attached it to the parking light if it'd blow the fuse.
Old 05-19-13, 08:56 PM
Adam350is
Adam350is's Avatar
first off, welcome to the forums! you chose the right car
interesting. looks pretty cool! let us know what happens! im sure theres a way.
Old 05-19-13, 09:21 PM
Sffd103
Fire Slayer
Sffd103's Avatar
Those look pretty cool. Think they'd fit.
Old 05-19-13, 11:15 PM
Nikon
Nikon's Avatar
definitely let us know if they fit. take pics!
Old 07-31-13, 10:29 PM
four o two
four o two's Avatar
I have switchback LEDs that I put into my housings. I modified my stock plug to accept 7443 because that was all that was available at the time.
Old 07-31-13, 11:17 PM
Nikon
Nikon's Avatar
i would love to have LED front signals. and rear for that matter. but definitely front.
Old 08-01-13, 01:44 AM
GiantsFan
GiantsFan's Avatar
For LED turn signals, can't go wrong with VLEDs "Platinum Amber" size 7440. I have them on my car and they are awesome
Old 08-01-13, 08:50 AM
jimjaix
jimjaix's Avatar
Is there a DIY for it? or do we have to bake the housing? JW
Old 08-01-13, 05:31 PM
GiantsFan
GiantsFan's Avatar
^you don't need to bake the housing to change turn signal bulbs.
You will need to modify your flasher relay or purchase one that solves the hyper flash.
Old 08-06-13, 10:29 PM
Nikon
Nikon's Avatar
is the daytime visibility in sunlight just as good as filament?
Old 08-06-13, 11:16 PM
Sango
Sango's Avatar
I saw the video. Those switchbacks are not brighter than incandescent, it definitely looked dimmer.
SMD's generally don't have the same output incandescent. It's even worse when it comes to procedure colors like amber and red since it's harder to have them produce the same lumens compared to the white. Plasma would most likely be the one to look for or maybe the V3 Triton (at a price!) to get something comparable to higher lumen output in comparison to incandescent.
Old 08-07-13, 01:48 PM
Nikon
Nikon's Avatar
bummer. the only thing that holds me back from going LED signals is I've yet to see an LED bulb that is as bright as incandescent and has good daytime visibility.
Old 08-07-13, 02:24 PM
GiantsFan
GiantsFan's Avatar
Depends which LED you get ...
Mine is pretty bright. Pretty close IMO to the filament bulb.
Old 08-07-13, 05:14 PM
See5
See5's Avatar
How can I adjust the relays? Or can you tell us about a ready relay for this issue.
Or just replace the LEDs ?
+ 7440 Is for both front and rear ? and how many Led bulbs do I need for a total switch.
Sorry for a lot of questions
thank you
Old 08-07-13, 10:37 PM
RX330iPad
RX330iPad's Avatar
What about these?
Quick Reply: LED turn signals
