Stretched tire problem PLEASE I REALLY NEED THE HELP
Old 04-09-13, 12:01 AM
lysis250
lysis250's Avatar
Exclamation Stretched tire problem PLEASE I REALLY NEED THE HELP
I don't know if I posted in the right or wrong forum section but mods please let it be up at least until I get my answer!!!
Is there anyone running 225/40/18 on a 8.5J wheel on their ISx50? The thing is I found some 18" wheels but the rim width is 8.5J and not 8.0J like the stocks. I read that if I use 225 on a 8.5J wheel it will be a bit stretched, is there anyone that has that setup so I can preview of what it looks like before I buy the rims. Is there also anyone running 255/40/18 on a 9.5J wheel?
Old 04-09-13, 12:46 AM
projectdna
projectdna's Avatar
225/40-18 on a 18x8.5 is not a stretch.
225/40-18 on a 18x9.5 is.
/thread.
Old 04-09-13, 09:29 AM
reyoasian
reyoasian's Avatar
225/40 on 8.5 is pretty standard lol
i have 225/40 on 8.75 and it's only ever so slightly stretched, yours will be fatter for sure
Old 04-09-13, 12:34 PM
felo2081
felo2081's Avatar
Yeah mine has a 225/40/18 and it doesn't even look stretch at all!!
Old 04-09-13, 01:06 PM
pmanliu
pmanliu's Avatar
225 on 8.5 (19's not 18's though) to give you an idea. Slight stretch. These rims are for sale too in the classifieds
Old 04-09-13, 02:47 PM
BernieIS
BernieIS's Avatar
This is something that is not a concern. You will be fine.
Old 04-09-13, 03:09 PM
lysis250
lysis250's Avatar
Thanks thats all I wanted was to see a picture on a ISx50 running this kind of setup hopefully I don't go wrong buying these rims.
Old 04-09-13, 04:50 PM
kuuqi
kuuqi's Avatar
You will be fine regardless.
Keep in mind SOME tires run slightly wider/taller than others. Comparatively, I had Continental DW tires with a 225/35/19 front and 265/30/19 rear and swapped to the same size tires with Hankook Ventus V12's and the Hankooks run slightly wider which caused an extremely mild rub. But of course that has more to do with your suspension specs.
Old 04-09-13, 05:07 PM
jdmSW20
jdmSW20's Avatar
yeah exactly what he said. some tires run wider than others so sometimes its dependent on what brand you are going with.
Old 04-09-13, 05:35 PM
lysis250
lysis250's Avatar
Is anyone running 255/40/18 on a 9.5J with bridgestone tires?
MadDane
Suspension and Brakes
03-18-14 05:34 PM
ASPLS430
03-15-12 10:47 PM
Maxx941
04-27-10 12:30 AM
Aclarke
05-26-06 10:35 AM
Quick Reply: Stretched tire problem PLEASE I REALLY NEED THE HELP
