The Oil Catch Can Experiment
Old 09-07-14, 12:52 PM
  #106
dannyboy26
dannyboy26's Avatar
Actually I looked up my order it was $29.99 but best $30 I have ever spent
Old 09-07-14, 01:08 PM
  #107
Ants350
Ants350's Avatar
Lol I just put an offer for one. Danny did you have to add stainless steel scrub?
Old 09-07-14, 04:40 PM
  #108
dannyboy26
dannyboy26's Avatar
the only thing I did was drill a hole to mount it, it comes with O rings so use them. The OCC is all you need no need to change anything but mount it where ever you feel, I just think where I mounted mine was the best possible spot
Old 09-29-14, 08:35 PM
  #109
liqB
liqB's Avatar
I just ordered one of these from the same guy. My cars currently at the dealer having the piston rings replaced. When routing the hose, does the hose that goes into the PCV go into the left side of the can and the exit goes out of the right side? or should it not matter?
So bought this ebay one that actually comes with filter and WOW!!! For the price its very impressive very compareable to a Mishimoto, one here are some pics of my set up... And since you can take the can apart I drilled an extra hole and used a rounded bracket to bolt in and then bolted that bracket to another one I mounted on the ECU housing and it looks great.... One other thing because of where I mounted my OCC I had to modify the eng cover to run the lines through as you can see in the pics but this can is well worth the $20 IMO im very surprised its only $20 from the craftmanship and how well its put together with the filter in the middle of the can it should be priced around $100
Old 09-30-14, 12:59 AM
  #110
dannyboy26
dannyboy26's Avatar
If you have the can facing you, the one on the left side is the inlet it has a little tube that goes past the filter and the one in the right goes back into the eng but take the cover apart just to make sure
Old 09-30-14, 07:00 AM
  #111
liqB
liqB's Avatar
Thanks!
10char
Old 10-18-14, 01:20 PM
  #112
liqB
liqB's Avatar
Just to clarify. The left side with the hose going into the bottom of the can should be hooked up to the PCV valve? and right side to the hose?
Old 10-18-14, 04:51 PM
  #113
dannyboy26
dannyboy26's Avatar
Yes that is correct the PCV valve coming from behind the intake goes into the opening with the tube and the other goes into the engine
Old 11-10-14, 11:54 AM
  #114
kevin125
kevin125's Avatar
I don't want to bring this thread back from the dead but i also don't want to create a new thread. i rather keep everything here for those in the future who has the same question. Has anyone had any problems at all with the lines or the catch can freezing? Reason im asking is because winter is around the corner for me and the car will be mostly in the teens or below (19 and below). My car has 100,900 on it now and recently had the TSIB aka bandage done on my engine. Does anyone know if it has given any problems of freezing in the winter?
Old 11-12-14, 06:16 AM
  #115
kevin125
kevin125's Avatar
Bump
Anyone have any experience with the oil catch can in cold weather?
Old 11-12-14, 06:55 AM
  #116
dannyboy26
dannyboy26's Avatar
Originally Posted by kevin125
Bump Anyone have any experience with the oil catch can in cold weather?
Our cars take 5w-30 for that sole reason that it can be used at any temps even -20F and below so I dont see a problem with the catch can in the winter besides you are not capturing much in the can
Old 11-12-14, 08:55 AM
  #117
Ants350
Ants350's Avatar
I read some horror stories about it freezing up and some say it's ok so I don't know myself..
Old 11-12-14, 01:29 PM
  #118
dannyboy26
dannyboy26's Avatar
If it freezes in the can it will also freeze in the actual oil Pan so I dont see how if anything you could always go with like 0w-20
Old 05-16-15, 07:11 AM
  #119
nyclexus11
nyclexus11's Avatar
Is this seller still selling on eBay? Can't seem to find the same one you used. It looks really nice. Do you remember the sellers name? Or if you can post the link, that'll help.
Old 07-18-15, 04:40 PM
  #120
g1itchgsr
g1itchgsr's Avatar
After 5k miles using the same catch can as OP
Quick Reply: The Oil Catch Can Experiment
