Throttle body cleaning
I am going to be cleaning my throttle body soon. Should I remove the entire throttle body and then clean it with the spray or should I just clean it with the spray while it's still on the car? If I remove it, How do I know what torque to tighten the bolts at?
Also, other than the air intake pipe and the electronic connector, what other connections need to be removed from the TB?
Thanks
Thanks
removing the whole throttle body is not necessary. just get throttle body cleaner spray, a rag and a old toothbrush. spray some in there clean with the rag. push the cover open and use the toothbrush. make sure you spray some in there and rev it up hard.
i would clean it everytime i change my air filter.
