inner tie rod end replace
Old 11-21-12, 09:05 AM
Asher
Asher's Avatar
Default inner tie rod end replace
i need to replace my inner tie rod driver side should i replace both or just the driver side???? which one should ill get ebay or oem is ther any differences pls help
thanks
Old 11-21-12, 10:19 AM
B16da9
B16da9's Avatar
I would replace both at the same time. If you decide to go aftermarket I would recomend the brand "Mooge".
Old 11-21-12, 11:00 AM
Asher
Asher's Avatar
Thanks for the quick reply ...thers a reason to change both ??
Old 11-21-12, 11:35 AM
Gville350
Gville350's Avatar
Its kinda like changing tires on a car; you might not really need the other tire to be replaced, but it is recommended for neutrality. I'd have to agree to go ahead with both.
BTW, it is spelled "Moog".
Gears12
Suspension and Brakes
24
10-16-12 07:25 PM
peterwho
06-21-10 09:22 PM
mk4r34
SC- 1st Gen (1992-2000)
03-18-10 02:55 PM
Quick Reply: inner tie rod end replace
