HELP! LED strip on 1 side wont light up on new 2012 Headlight
Old 10-14-12, 09:10 PM
Ryan5157
Ryan5157's Avatar
Cool HELP! LED strip on 1 side wont light up on new 2012 Headlight
I just got done installing the Sewell 2012 Headlight upgrade and everything works but the LED strip on the passenger side! What could the problem be and how to fix it?? Need to fix asap!
Old 10-14-12, 09:48 PM
rookieIS
rookieIS's Avatar
easiest fix is to contact Sewell and they'll get you a replacement
Old 10-14-12, 09:50 PM
RDIS250AWD
RDIS250AWD's Avatar
is everything wired up correctly? I would've said check your fuses but that wouldn't be the case if the other one is working. So it has to be your wiring. If not contact sewell
Old 10-14-12, 10:09 PM
Snyperifle
Snyperifle's Avatar
If it's 2012 it still has warranty right?
Old 10-14-12, 10:13 PM
RDIS250AWD
RDIS250AWD's Avatar
^sewell has a 1 yr warranty on their headlights
Old 10-15-12, 12:22 AM
Ryan5157
Ryan5157's Avatar
Cool
it is just a plug and play on the 2012's right? if so, it looks like everything is plugged in right. anybody have a wire diagram for them? i am also using after market HID's... but i wouldnt think that would have an effect it...
Old 10-15-12, 04:26 AM
iRyan
iRyan's Avatar
if one side work and the other doesn't its the light issue or you didn't plug it up correctly, Check the plug up for the LED board and the plug up for the whole light unit, if all that is good then call Sewell for replacement, from Sewell it's plug n play
Old 10-15-12, 06:36 AM
ohiois350
ohiois350's Avatar
maybe sewell did rewire one led's side and forget the other side? just take both lights off the trace the wires to see if they are in the same harness plug location? if they are, so it time to contact Sewell
Old 10-15-12, 07:53 AM
runyun
runyun's Avatar
Easiest way is to check the wire colors on both headlights (going to the big white connector)
I bet like what ^ said, they may have sent you one that was prewired - and the other wasn't wired.
Repinning it is pretty simple.. just need a toothpick or something small sharp to release the pin.
Old 10-15-12, 08:08 AM
Ryan5157
Ryan5157's Avatar
ok. i checked every wire out thoroughly and they all looked good, so i swapped sides with the lights and it still didn't work. so i have been trying to call Sewell this morning but keep getting the answer machine.
Old 10-15-12, 08:16 AM
ohiois350
ohiois350's Avatar
email for a quick respond friend
Jaytran
06-17-17 05:03 PM
Rolando
02-24-16 04:21 PM
lexus316
05-10-15 04:54 PM
LiLS
04-10-13 05:15 PM
LiLS
IS F (2008-2014)
04-08-13 10:31 PM
Quick Reply: HELP! LED strip on 1 side wont light up on new 2012 Headlight
