2007 IS350- AC blow cold only on max- HOT after 65??
Old 10-13-12, 07:48 PM
uMulla
uMulla's Avatar
Default 2007 IS350- AC blow cold only on max- HOT after 65??
I have a 2007 IS350 with only 54k miles
On the inside the outside temp reads fine about 90F depending on outside temp
When the AC is set to max cold it blow cold air fine
When AC is set to 65 or above the heater kicks in and blows HOT air.
I have looked around and seen people with same problem.
can it be a sensor behind the headlight or climate control head?
Old 10-13-12, 10:26 PM
whitebeast
whitebeast's Avatar
Stop by at pepboys and have them check out. You may need to refill some 1034a.
gssteve
GS - 1st Gen (1993-1997)
10-05-12 07:58 AM
Och
14
07-19-08 05:27 PM
ajcsanders
06-26-06 01:41 PM
Quick Reply: 2007 IS350- AC blow cold only on max- HOT after 65??
