IS250 Carbon Build up CSP
Old 09-29-12, 06:04 AM
  #76
Road Rage
Road Rage's Avatar
diagtime is dead on correct. But the use of the word "create" should really be "duplicate". If we can't duplicate a condition, we can't do squat about it. All your SA needs is L-TT-0093-12 and he/she can pull it up in TIS.
Old 09-29-12, 09:22 PM
  #77
flyfl1pguy
Registered User
flyfl1pguy's Avatar
just picked up the car today and when i got home tonight noticed a few issue with the repair.
As I was backing into my garage, I noticed a clicking sound coming from the engine bay. I took a closer look and noticed that the coolant level is low. Also, a leak coming from the seal area where it seems that the work was done.
THis is very disturbing, knowing that the repair was done, but it seems that it wasn't done right.
See image. What shall i do?
Old 09-29-12, 09:37 PM
  #78
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
Originally Posted by reyoasian
awesome news....for canada too?
Yes.
Originally Posted by zen
tks for the heads up and a great info !
The letter only stated the yr from 2006 - 2010 IS250 and IS 250C, so I guess from the 2011+ is not qualify for this CSP ?
9 yrs with unlimited mileage is a long way to go
2011+ models are not covered.
Jeff
Old 09-30-12, 07:34 AM
  #79
Road Rage
Road Rage's Avatar
Take it back. I can't see anything in that first pic but the second clearly shows coolant mixed with FIPG which means something in the front cover wasn't sealed properly. Good news is that if you don't have a check engine light by now then at least all the timing chains were set correctly, which is the most common mistake for this repair.
I hate the 250 so much.
Old 09-30-12, 08:02 AM
  #80
Road Rage
Road Rage's Avatar
Just so you guys have some idea of what is involved in this "repair", this is not just changing out parts. It's a total rebuild of your engine. I've included some pretty low quality pics of the process.
Old 09-30-12, 09:50 AM
  #81
sgmbab
sgmbab's Avatar
Does this includes changing all the fluids too (brake, transmission, differential, & coolant)?
Old 09-30-12, 10:07 AM
  #82
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
It would require changing the coolant and engine oil. Nothing else.
Jeff
Old 09-30-12, 10:11 AM
  #83
supralative
supralative's Avatar
Originally Posted by nitrotang
How's it run now? Anymore rough idles?
this was known through the service history of the car
as of now though with my ownership of it the car drives fine
Old 09-30-12, 10:15 AM
  #84
flyfl1pguy
Registered User
flyfl1pguy's Avatar
checked the coolant level this morning and it is now on the low level side. Pretty sure it was between low full last night.
This is starting to be a pain. This car is such a headache! starting to want to give up on it and just let it go. . .
Old 09-30-12, 10:30 AM
  #85
NimaM
NimaM's Avatar
After seeing those photos above, I'm kinda glad I sold my IS250...
Old 09-30-12, 05:56 PM
  #86
flyfl1pguy
Registered User
flyfl1pguy's Avatar
I really hate having this kind of issue with the car, but its happening. I'm about 75% thinking about letting this baby go. .
Old 09-30-12, 06:04 PM
  #87
diagtime
diagtime's Avatar
A tech screwed up the job. don't blame THIS ONE on the car. I'm sorry for your troubles......... if you drive it back, better watch the temp gauge and if gets even slightly over normal pull over and have it towed. towing is the safest option to begin with. You have the right to be upset....but not with the car. Let them know how mad you are. It will ensure that this time it's taken care of properly.
Old 09-30-12, 07:46 PM
  #88
My0gr81
My0gr81's Avatar
Originally Posted by Jeff Lange
Yes.
Jeff
Was there a significant design/component change on 2011+ models? Can you or anyone elaborate?
Old 09-30-12, 07:51 PM
  #89
ghwanee
ghwanee's Avatar
Will this problem ever come back after the CSP is completed? or is it a continuous battle?
Old 09-30-12, 11:08 PM
  #90
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
The parts currently being installed on the 2006-2010 models as part of the TSB are the ones that were installed at the factory on 2011+ cars.
Jeff
Quick Reply: IS250 Carbon Build up CSP
