XenonDepot - Customer Service is second to none.
Former Sponsor
Vroomin350: It would be my pleasure to help you out!! Are you looking to swap out the low beams on your vehicle to H11? I thought the 07 IS uses 9006 bulbs for the fogs? Check out this page for more information about our HID replacement bulbs. Send me a PM with what you need and I will definitely help you out!
bob4256: Thanks bud =) I sincerely appreciate the referral.
Steve
Steve
Former Sponsor
gerill2p: Upgrading your fog lights to HIDs is a plug+play upgrade. The kits come with a proper 9006 connector that will literally plug into your OEM fog light harness. The ballasts that come with the Xtreme HID Kit are super low draw meaning that you can safely power them directly from the OEM fog light wiring. Furthermore, in auto mode your fog lights typically turn on when the vehicle is starting (assuming that your lights are on). When this happens there is a drop in power from your OEM fog light harness. Xtreme ballasts can handle this power drop meaning that you will not encounter any issues with one side not turning on intermittently like you do on other kits.
Steve
Steve
Former Sponsor
Hi Guys,
heyarms: Will respond in a min
pchan0: From personal experience (I've had both installed): I find that looking directly at the bulb the jet yellow bulbs appear to be "yellower" depending on what angle you view the light from. However, 3000k HID kit will provide you with more light output and more noticeable "yellow" light on the road.
Steve
Steve
Steve
Steve
Thanks steve, you are absolutely correct however I am no longer in a 2007
Reason I want just bulbs is because I already have a set of ballast sitting at home.
