it's probably just the connection if you've already tried flipping it upside down
I have drl parking lights and it has that problem mine doesn't connect when it's fully plugged in so i had to pull it out a little bit so it's not fully plugged in, and then i used electrical tape to keep it tight in place
so it's probably just the metal strips on the led too short
And if its not the fuse... Which it could be... Try using bulb lube to get a better connection as mentioned earlier. I had this issue with a turn signal and thats all i needed.
