How to fix vled turn signals hyper fast blinking?
Old 02-14-13, 10:31 AM
IamNate
IamNate's Avatar
Originally Posted by sm1ke
Wondering this is well. I bought a set of LED turn signal bulbs for the front and rear. My car is an 08 IS250.
Edit: Nate, could you link to the flasher relay again? The other link leads me to a 404 error.
Sure here it is...
http://www.vleds.com/toyota-electron...ignal-fix.html
Old 02-14-13, 11:01 AM
sm1ke
sm1ke's Avatar
Thanks GiantsFan for the DIY. So you just grind the metal U off completely?
Old 02-14-13, 12:47 PM
GiantsFan
GiantsFan's Avatar
NO!
Grid off little by little (taking away the thickness) and test it each time till the hyper flashing stops. One you hit the correct thickness where the hyoer flash stops, grind a little more and stop.
That's it!
Old 02-14-13, 12:52 PM
sm1ke
sm1ke's Avatar
Do I just grind the top of the U only, and not the sides?
Edit: I'm so glad I bought a rotary tool all those years ago. It made so many projects that much easier lol
Old 02-14-13, 12:59 PM
GiantsFan
GiantsFan's Avatar
I grinded all the sides so no single area would become too thin.
Old 02-14-13, 07:46 PM
pmanliu
pmanliu's Avatar
GiantsFan, thanks for your help. Quick question... if i grind the U and decide to install regular bulbs back later on, does everything still work as normal?
Old 02-14-13, 08:03 PM
GiantsFan
GiantsFan's Avatar
No, I don't think it would work with regular bulbs...
If you want to read up more on this check out this link:
http://v-ledsblog.com/2010/12/02/how...k-with-v-leds/
This simple modification will allow you to change the value of the flasher units resistor hoop to match the value of your V-LEDS ... All that needs to be done is to remove some material thickness from the hoop. This will change the value of the hoop, and by doing so changes the value to match that of your V-LEDS.
Old 02-15-13, 12:08 PM
es808
es808's Avatar
Post
Reading the v-leds post, it compares the wattage draw for the bulbs and compares it to the flasher unit. If the bulb wattage is lower than the flasher unit, it will hyperflash. But this is not to say that if the bulb wattage was higher than the flasher unit, it wouldn't flash normally.
This may be something to try out. If I get the chance, I'll try it this weekend if I still have my stock bulbs.
For everyone attempting this, be patient and take your time. It took me about 10 attempts before I got it right. If you take off too much, you'll have to order a new flasher relay and start again. GL!
super400
SC- 1st Gen (1992-2000)
08-03-16 08:34 PM
TRACKMKIII
GS - 1st Gen (1993-1997)
01-09-15 06:17 PM
TitanFan
01-03-13 09:30 AM
caliness
Lighting
08-02-04 07:35 PM
Quick Reply: How to fix vled turn signals hyper fast blinking?
