Running a taller tire profile
Old 06-21-12, 06:17 PM
exit9
exit9's Avatar
Default Running a taller tire profile
Hey guys.
I've had my IS350 AWD for almost a year now and one of my not so likes is the amount of tire noise that gets into the cabin. I've swapped out the standard tires that came with Michelin MXM4 but no joy. Thinking of running a taller profile 225/50/17 or 225/55/17 (I know speedo will be off) to quite things down a bit. On textured road surfaces it sometimes gets pretty loud and distracting. Any thoughts? Issues with fitting?
Thanks.
Old 06-21-12, 08:56 PM
Sango
Sango's Avatar
Probably don't want to do that especially with AWD.
The other thing is that since you have AWD, because you have AWD because the transfer case is right below and the side of the right foot. More moving parts = more noise. With RWD, it is quieter.
Old 06-21-12, 10:53 PM
Dawa
Dawa's Avatar
moving from a 50 series to a 55 series will only increase your sidewall height by 11.25mm OR .45 inches. i feel like this shouldnt cause any clearance/fitment issues. go out to your car with something that is roughly .45 inches and put that atop your tire, then rotate it around your tire and see how much clearance is left.
Old 06-22-12, 08:23 AM
4TehNguyen
4TehNguyen's Avatar
speedometer will be slightly off if you deviant from the original overall diameter.
Old 06-24-12, 05:03 PM
exit9
exit9's Avatar
Yeah speedo will be off. Willing to live with that. Once the threads get low I'll switch to Continentals DWS. Hopefully, I'll have a better experience with them.
Old 06-24-12, 05:30 PM
zx7rou812
zx7rou812's Avatar
Increasing the sidewall height is NOT your solution. That will only put MORE tire on the road. Side effects include inaccurate speedometer reading, reduced fuel economy, and potentially MORE tire noise.
I swapped out the pathetic Potenzas (Really Lexus? A 140 treadwear fragile Summer rated tire on a $40k car sold in New England???) for a set of Kumho Ecsta 4X's (Model KU22).
Road noise is nonexistant and I've gone up almost a mile a gallon in fuel economy to boot. 420 treadwear in an all season pattern should mean at least 55k miles out of them. Wet traction is still the same. Dry traction feels the same as well (I don't bomb around like Ricky Racer).
Old 06-24-12, 06:21 PM
slimjimtel
slimjimtel's Avatar
Go rent a car, say a dodge or Chrysler product, drive it for a day, THEN drive your IS, you will then realize how quiet your car is!
Old 06-24-12, 08:33 PM
4TehNguyen
4TehNguyen's Avatar
treadwear numbers are not standardized between manufacturers. Youre not going to get 55k on a staggered undirectional set of tires.
Old 06-24-12, 09:33 PM
ISNIK0802
ISNIK0802's Avatar
http://www.tirerack.com/tires/tires....nce+ComforTred
Hey I have an IS250 AWD. I have these tires at 225/55/R17 theres very minor rubbing in the front it can only be heard when breaking hard into a turn or sometimes when making a U-turn. It's very minor rubbing. Ive had these for a year now, definitely noticed a better quieter ride than the stock tire and these have a lot of grip wet or dry. I'm glad I bought these tires!
Look into them!
Old 06-24-12, 10:21 PM
Sango
Sango's Avatar
Are you sure its Potenzas? It's more like the Bridgestone Turanza ER33 which is 140. I have them stock on my car but was advised not to to spoil them. They are notorious for road noise.
After I wear these to the ground, I'll switch to Michelin Pilot Super Sport tires.
Old 05-27-14, 07:54 AM
pmanliu
pmanliu's Avatar
bump, does anyone have 225/50/17 on their lowered ISx50s? Im dropped on tein s-techs, and running 225/45/17 now. Contemplating these but afraid of rubbing...
sandlu
02-01-17 10:02 AM
306Lexus
11-25-14 02:52 PM
rowfei
RX - 3rd Gen (2010-2015)
10-07-11 06:48 PM
TriggrHapy
Wheels, Tires & Brakes Forum
03-29-11 06:43 AM
dandg
06-28-07 09:36 AM
Quick Reply: Running a taller tire profile
