mark levinson stereo
Old 06-10-12, 03:46 PM
6lexis350
6lexis350's Avatar
Default mark levinson stereo
I have a 06 lexus is350 with the mark levinson set up. If i put the volume past 34 the volume shuts off, turns on again. It does this repeatedly. If i set the speakers up to where it only comes out through the back, then it works good and i can turn it up to max without it shutting off. Does anybody know what it can be?
Old 06-10-12, 10:46 PM
nosurprise
nosurprise's Avatar
I heard that though the ML sounds good, it's unreliable and just breaks after a while.
Old 06-10-12, 11:32 PM
projectdna
projectdna's Avatar
either the ML amp is overheating and shutting down before any physical damage can be done to the amp, or there's a short in the amp itself.
i also heard that the crescent of the moon is based on the alignment of the earth and the sun, but the moon itself is made of crusty gray cheese.
fact is, there hasn't been widespread ML amps failing and needing replacement. but if you're the type that requires volume to always be past 40, something's bound to break sooner or later...
Old 06-10-12, 11:35 PM
KillaIS250
KillaIS250's Avatar
x2 on the amp probably being the issue. If all your speakers cut off past that volume, i'm almost certain its the amp.
Old 06-10-12, 11:41 PM
faisal11ir
faisal11ir's Avatar
5 years and still giving great sound.
Old 06-11-12, 08:02 PM
rogzballz
rogzballz's Avatar
Amp ... If you need it that loud, Change it for a real aftermarket setup
Old 06-11-12, 08:37 PM
ohiois350
ohiois350's Avatar
it happen to me once, right after I got my rear view mirror under TSB, and test to see how the new rear view mirror can handle the shake, I turned the volume up to 35 and all sound cut off, even I turn off the radio and back on still no sound, wait for 10 mins turn back on still no sound it freak me out, and I got home and the next day I turn the car on and the radio it work like normal again, after that I never turn the volume more than 30
Old 09-28-12, 07:53 AM
POGX470
3rd Gear
POGX470's Avatar
Were you able to find a solution to this? I am having the same problem
Old 09-28-12, 10:00 AM
cbishop11
cbishop11's Avatar
Yep, sounds like the amp going into safe mode, usually from overheating. Time for a new amp!
Old 09-28-12, 04:08 PM
anthrax144
anthrax144's Avatar
Dang! Just looked on Sewell. The replacement ML amp is $1810 after CL discount!! OUCH!
Old 09-28-12, 07:35 PM
Shervin350
Shervin350's Avatar
does the whole navi shuts off? or the sound?
Old 09-28-12, 07:40 PM
Evitzee
Evitzee's Avatar
6+ years and ML amp and speakers just doin' fine, but I don't crank it up, that's what my home system is for.
YGuan96
06-21-15 06:57 PM
sheriffwoo
10-13-13 08:31 PM
iboon
12-07-10 02:40 PM
tqlla3k
09-18-06 06:29 AM
KevinGS
09-04-05 12:47 PM
Quick Reply: mark levinson stereo
