Passenger window not working from master switch
I replaced my blown tweeter on the driver side so I went on ahead and switched out the passenger side also. As soon as I put everything back together i noticed the passenger side window will only work on the passenger side switch. I also noticed when pulling off and on the master switch sometimes the auto down and up for windows will work and then not work. Im all confused. Fuses checked good, I opened the master switch also its good. Any advice?
you need to reset the window regulator since you probably disconnected the passenger switch. Pull the switch to roll up your window and hold for 3 seconds and then push and open your window and hold for 3 seconds.
KiNGD206
01-10-14 07:13 PM
LRP_LS400
08-29-07 04:06 PM
