Cost to repair/replace dashboard?
Sorry man with due respect I disagree, did you look at that last picture? looks like finger streaks from a melted dashboard
Wether he banged out those holes or not they should replace his dashboard. Now if he has a hole in his seat, thats something else. I am not one to try and pass anything off but if the issue is there I will find a solution somehow. Lexus drains people's wallets on a daily basis. A simple 2 hour job am sure wont break their bank.
I guess its all good if OP gets his dash replaced. I'm just saying if I did the damage and it was reasonable based on whatever i did to damage it, I wouldn't try passing the problem onto Lexus. Everyone's different tho!
Give Lexus Corporate a call and see what they can do. The worse thing they can do is say no. Bring up the TSIB for the melting dash and let them know yours fits the TSIB, but simply isn't under warranty and you'd like to see if they are willing to do anything to correct the matter and keep you happy as a customer. I've seen that usually they will offer you some sort of help. Either way, it can't hurt to call and ask.
Furthermore, even if the damage was caused by the sticky melting dash, the dealership would still have to see proof of these symptoms. So OP would have to bring it in while it was exhibiting the symptom of the sticky melting dash, or the dealership would have to keep the car till the problem manifested itself.
So no, the sticky dash TSIB does not apply here. Furthermore, the car would still have to be under the factory warranty (4 yrs/50k miles) for this TSIB to be covered by warranty anyway. I don't know the year and mileage of the OP's car, but if it's out of this period, the TSIB is totally irrelevant. Even if the marks were caused by a sticky, melting dash, it would be out of pocket because he'd be out of warranty.
OP - your best bet is to start shopping around for a dash pad. It's sold as one big piece and will be expensive. I'd look for salvage junkyards.
In this particular case, no the sticky dash TSIB would NOT be covered by CPO, because CPO expressly does not cover body and interior trim pieces (which includes the dash pad).
It certainly can't hurt to try. Understand there are no guarantees - as you yourself said for you it is no longer covered at all because you're out of warranty. So Lexus would have to do this goodwill. I'm going to bet at best they'll offer to pay half, or either labor or parts and you cover the other. Definitely call and complain, mention that many people are having this problem and there's a TSIB for it, and hopefully you'll get some recompense.
You're understandably bitter about your own poor dash experience. But in this situation, this damage is very clearly NOT related to the TSIB. The TSIB will only be performed if specific conditions or symptoms are present - in this case, a sticky or melted dash. From the pictures, this dash clearly is not suffering either symptom - it's just been scratched. And the last picture doesn't look like fingers streaks from a melted dashboard, it looks like fingernail scratches. Very different.
Really? mine looked just like that and it was replaced
Never once did I intentionally scratch my dashboard, all I did was try to remove my sunshade and my hands touched the dash and VOILA, looked just like OP's..
correct, I took mine in on the instructions of corporate for pictures.. was given an answer that same day, I wish I had taken pictures of mine, LITERALLY looked like OP's. An area manager who happened to be at the dealership saw it himself and said "dont even bother calling corporate back, we know about this and will take care of it..... so looks like it wont be a problem for them to determine it is caused by the known issue
1. So no, the sticky dash TSIB does not apply here.2. Furthermore, the car would still have to be under the factory warranty (4 yrs/50k miles) for this TSIB to be covered by warranty anyway. I don't know the year and mileage of the OP's car, but if it's out of this period, the TSIB is totally irrelevant. Even if the marks were caused by a sticky, melting dash, it would be out of pocket because he'd be out of warranty.
1. Wrong, it is obvious on that last picture that due to the material softening/melting it was easy for OP to leave those marks behind.
2. I was out of warranty, 59K miles and wayyy past my four years.... I never argued it would be free and the TSIB will cover it with no out of pocket expense, but they WILL work with you.
What this means is that either 1) your dealership covered it goodwill, or 2) Lexus corporate decided to pay for it. Regardless of what happened, you didn't have to pay for it but it wasn't technically covered by warranty.
Each case is different, so when people ask questions I answer with the explicitly stated answer from Lexus. I of course encourage the OP to call Lexus and complain and try and get a different answer, as you obviously did.
I should also mention I was basing my answer on the OP's description, within which he used the terms "scratched" and "torn", implying someone or something scratched and tore his dash, and nowhere did he mention his dash was sticky and/or melting at any point. If it was, that would change things, but I assumed if that were they case he'd have mentioned it.
The hole and deeper marks are actually not that difficult to repair, the srcatches on the right hand side can't really be fixed, but they can be made less visible. You can find someone to half *** it for $25-$50, but a good repair will be more like $100-$150.
$224, I was out of warranty and went through lexus corporate. Call them. They will tell you to take it to a dealership so they can get pictures. Explain that these "gashes/holes" happened by you simply touching and running your fingers on the dashboard. Honestly even though it looks like you did that, no TRUE non defective dashboard should do that. Most likely they will pay labor and you pay parts.
