DIY: 2006 IS250 sealed transmission replacement
Old 04-17-11, 02:34 PM
whazzzzuup
whazzzzuup's Avatar
Default DIY: 2006 IS250 sealed transmission replacement
Hey guys. Here are some pictures for you members that may need to replace their IS250 RWD transmission. My friend and I completed this in our garage. We spent time on it after we got off of work. I think it took a total of 20 hrs combined. We got a transmission off car-part-com for $850 shipped. Shifts so smoothly!
Keep in mind: we are both in the health care field; not mechanics. So if we can do it, you can too!
The car was jacked up and supported with 4 jack stands. The front jack stands were positioned higher than the rear stands. 2 wheels were put under the front wheels for safety as well. The front was up about 21 inches and the rear about 15 inches:
Here is the side views of the "new" transmission:
Before you can take out the starter, you must remove the driver's-side header:
The starter has two 12mm bolts holding the nuts in. Remove those, remove the 2 14mm bolts that hold the starter in, and the starter will be free:
Remove the steering shaft (by driver-side header):
Before you remove the passenger-side header, you must remove the intake, oil dipstick, wiring harness to the front two coil packs, and vacuum hoses by the shock tower.
Disconnect the headers from the y-pipe and remove the passenger-side header as well. Make sure you unplug the primary o2 sensors:
Disconnect the hoses from the heat exchanger:
Another view:
View of passenger-side header:
Remove transmission bolts. There is 11 bolts total; 2 to the starter:
From left to right (12 o'clock going clockwise):
Undo the bolts that connect the flywheel to the torque-converter. There are six 14mm 11-grade bolts. They are held on really tight. Make sure you hold the crankshaft in place when you remove these or the entire flywheel/torque converter assembly will move.
The new torque converter with the 6 14mm bolts attached (so I don't lose them):
Bell-housing:
Torque-converter:
Remove y-pipe, along 2 secondary o2 sensors. I used a 24mm socket with a slit down the middle of the socket:
Here is the half-shaft (removed):
Half-shaft (transmission-side/attached). It just pulls out smoothly after the bolts that secure the half-shaft are removed:
Transmission/half-shaft spindle:
Half-shaft (four 14mm bolts and nuts):
Remove transmission mount/bracket:
Some of the parts removed:
The following 2 users liked this post by whazzzzuup:
chriso5573 (04-30-17), Viru (02-21-18)
Old 04-17-11, 02:35 PM
whazzzzuup
whazzzzuup's Avatar
Remove shifter link and attach to new transmission:
Old transmission coming out:
Transmission out:
New transmission with half-shaft attached:
Flywheel (where the torque converter attaches):
When the new transmission lines up this pin will help with the process. You can adjust the torque converter to line up with the flywheel by sticking a hand into the starter hole, reaching back there and moving it.
Reinstall in reverse. Good luck! Thanks for looking.
P.S: These pictures should also help a member that may wanna just install headers or an exhaust.
Viru (02-21-18)
Old 04-17-11, 02:39 PM
chris07is
chris07is's Avatar
nice, but looks like tons of work..but why would u replace your transmission? something wrong with it?
ISThree
ISThree's Avatar
wow! great DIY!
Old 04-17-11, 02:52 PM
whazzzzuup
whazzzzuup's Avatar
I forgot to mention in the first post. The transmission was slipping in first and second gear. I think it was due to driving the car with summer tires in the snow.
Old 04-17-11, 06:06 PM
chikoo
chikoo's Avatar
You guys must be surgeons...
Old 04-17-11, 06:20 PM
Sango
Sango's Avatar
New field, car surgeons!
Old 04-17-11, 06:25 PM
twenty
twenty's Avatar
I was thinking the same thing!
Looks like *a lot* of work.. congrats for doing it yourself! I hope I never have to do this.
Old 04-17-11, 06:29 PM
BoOst3d
BoOst3d's Avatar
did you check to see if the tranny was still under warranty? i thought they had a 100,000 mile warranty on drivetrain?
davyjordi
davyjordi's Avatar
that's super impressive.
Old 04-17-11, 06:40 PM
Jeff Lange
Keeping it Real
Forum Moderator
Jeff Lange's Avatar
While I've changed a few trannies, I find the most impressive part to be the picture taking. It would take so much longer if you were always stopping to take pictures, haha.
Jeff
Old 04-17-11, 08:02 PM
javyLSU
2IS OG
javyLSU's Avatar
I agree with Jeff - great work, thanks for posting the DIY and pics!
Javier
Old 04-17-11, 08:07 PM
Nikon
Nikon's Avatar
why the change??? thats my biggest question. new owner here.
Old 04-17-11, 08:14 PM
wyee99
wyee99's Avatar
I'm going to save this as my favorites
Old 04-17-11, 11:06 PM
whazzzzuup
whazzzzuup's Avatar
The basic drive train warranty is 6 year/70k miles.
Nikon, please look at post #5.
Thanks for all the comments, guys! If you guys have anymore questions, I would be happy to answer them!
Quick Reply: DIY: 2006 IS250 sealed transmission replacement
