Can you turn off Traction & Stability control completely
Old 04-09-11, 09:10 AM
stanjohn12
stanjohn12's Avatar
Question Can you turn off Traction & Stability control completely
Just wanted to know if the Traction and Stability controls in the 2010 Lexus IS rear wheel drive models, be completely turned off ?
Will appreciate valuable inputs. Thanks.
Old 04-09-11, 09:18 AM
JEFFOS69
JEFFOS69's Avatar
To my knowledge it should be the same for 07+.
While stopped press and hold the traction control button for about 5 seconds until both traction lights light up (the trac and VSC or whatever it's called)
It's now off. It will turn back on if you press the button or turn off the car.
Old 04-09-11, 09:28 AM
stanjohn12
stanjohn12's Avatar
Question
Thanks Jeff, but i heard in certain reviews that the electronics(Traction control) still do interfere even if turned off to avoid rear wheels from sliding out. Is this true ?
Does it mean that one of the 2(Traction/Stability) will be on although it shows itself as off ?
Old 04-09-11, 09:32 AM
JEFFOS69
JEFFOS69's Avatar
Pretty sure they're totally off when you do this. If you just tap the button and only the trac light comes on (one) then it is not totally off. You have to press and hold.
Old 04-09-11, 09:47 AM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
If you press and release the button, traction control turns off, VSC is still on, and when your speed increases, traction control will turn itself back on. If you press and hold it for 3 seconds, traction and stability control (VSC) turn off. At this point there is no interference, and it will not re-enable itself. It is totally off at this point.
EDIT: Until you turn the car off, then it resets.
Jeff
Old 04-09-11, 09:53 AM
stanjohn12
stanjohn12's Avatar
Smile
Alright ok ok I get it. Thanks Jeff.
If you don't mind me asking , (it's Off topic) did you have a tire noise issue when you purchased your vehicle ?
If so how did you remedy it ?
Last edited by stanjohn12; 04-09-11 at 09:55 AM. Reason: Needed to ask one more question
Old 04-09-11, 09:57 AM
stanjohn12
stanjohn12's Avatar
Smile
Jeff
Alright. Thank you Jeff.
keneaise
RX - 4th Gen (2016-2022)
12-08-20 08:23 PM
SC430Sam
03-23-08 12:01 AM
italiandud
08-27-07 05:18 AM
donm3ga
04-03-07 02:26 PM
Quick Reply: Can you turn off Traction & Stability control completely
