Will 2008 IS-F grille insert fit 2007 IS350?
I've been wanting to upgrade my 2007 IS350's front grille insert to the F-Sport/IS-F style grille insert, with the mesh that matches the lower grille mesh. I understand Lexus makes an F-Sport grille insert for the '09+ IS, but not the '06-'08. I've found this knockoff on eBay, but it's pretty steep for a Chinese replica at $200:
http://cgi.ebay.com/ebaymotors/06-08...Q5fAccessories
This CL member installed it on his '06-'08 IS and I like it a lot, I just feel it's a bit expensive for a cheap replica:
https://www.clublexus.com/forums/6201064-post121.html
Then I thought, could I just buy the 2008 IS-F grille insert? Sewell has it for $177 (here, or see below screenshot: http://is.sewellparts.com/oem-catalo...-ISF-2008.html), so only a bit less than the above replica, but at least it's real.
So does the 2008 IS-F grille insert fit in the '06-'08 2IS?
Thanks!
Thanks!
I tried to suggest this in another thread that has since been deleted, so I'll try again here. OP, have you seen this one?
At a glance, it looks quite similar to the $200 one you linked. I've been mulling over it the past few days and thought I'd share.
So, who's going to be the first and post pics?
