My Tach needle is dying :*(
Old 12-03-10, 08:18 AM
jewel
jewel's Avatar
Default My Tach needle is dying :*(
I doubt this can be easily fixed right? It bugs the hell out of me
Attached Thumbnails My Tach needle is dying :*(-20101202_004.jpg   My Tach needle is dying :*(-20101202_003.jpg
Old 12-03-10, 08:21 AM
dappy
dappy's Avatar
I have the similar problem. I contacted the dealership and they said they wouldn't be able to fix it since the whole gauge assembly would need to be removed. Not sure how many others have the same problem?
Old 12-03-10, 08:26 AM
relaxfoo
relaxfoo's Avatar
damn that sucks bro...it's not covered under warranty?
Old 12-03-10, 08:42 AM
Kurtz
Kurtz's Avatar
He has an 06, virtually all 06s are outside of the normal factory warranty period at this point.
Old 12-03-10, 08:44 AM
jewel
jewel's Avatar
and I'm at 97k miles :P
I can adjust the cluster light setting, and the tip of the needle will flicker on and off. The base of the needle is dead though
Old 12-03-10, 08:57 AM
Sango
Sango's Avatar
A new cluster is about $1500 or above if I recall correclty.
Old 12-03-10, 09:04 AM
nissan454
nissan454's Avatar
that sucks !! sorry to hear that
Old 12-03-10, 09:17 AM
ISThree
ISThree's Avatar
PM LED guy (used to be under 2slow)
https://www.clublexus.com/forums/mem...4-led-guy.html
he might be able to help.
see this thread for more info
post #6 might help too!
https://www.clublexus.com/forums/is-...e-cluster.html
Old 12-03-10, 09:25 AM
RangerJoe
RangerJoe's Avatar
My tach and speedo are doing this. It's been getting worse for a while, just haven't taken it in. I got my 06 CPO, so hopefully they will cover it. I haven't been to impressed with the warranty coverage so far though.
Old 12-03-10, 09:48 AM
ScKcBc
ScKcBc's Avatar
its prob just a bulb man. Take it apart
Old 12-03-10, 10:02 AM
ISX50URRA
ISX50URRA's Avatar
My 06 IS250 is also suffering from this same problem! I have been considering buying a used one but if I do swap it out it will be for a IS-F Cluster.
Does any one know if the IS-F Cluster just plugs up?? any info would be great thanks!
Old 12-03-10, 10:21 AM
Micaiah
Micaiah's Avatar
Isn't it a bunch of little teeny led's that have to be soldered? I don't know why that's popping into my mind....
Old 12-03-10, 10:33 AM
DaKi3241
DaKi3241's Avatar
hmm more like time to swap with an IS-F gauge cluster
Old 12-03-10, 10:40 AM
Kurtz
Kurtz's Avatar
Reason 793 I bought the 8 year warranty
Old 12-03-10, 10:44 AM
IXI187IXI
IXI187IXI's Avatar
not unless you have an extended warranty. im sure your over the 4yr/50k standard lexus warranty.
Quick Reply: My Tach needle is dying :*(
