Will those Wheels Fit an IS250 AWD - Part Uno
#151
2IS guys i really need help. i cant find my answer on the gs side. i have a 06 awd gs300. i have a set of 19'' hre wheel i wanna put in. its 8.5 front and 9.5 rear on 42mm off set on all 4 wheel. my question is what is the idea size tire for it with out rubbing after i drop it about 2 inch. and does any company make air suspension kit for awd gs?
#155
Depends on how low you are, how much you're willing to stretch your tires, and how much camber you want to run.
I have 19x9 and 19x10 et 24 with 215-35-19 and 225-35-19 tires. I had to roll my fenders and stretch the tires. The wheels poke just a bit, but thats what i wanted.
Anything is possible. Its all in how much work you want to do
#156
#159
a little different scenario here...not going to ballin rims or anything like that, just wanted to see if anyone thought my old winter rims would fit the 250 AWD?
they're the stock 8thgen civic rims, 16"x6.5 i believe. +45 offset, 5x114.3 of course, 64.1mm bore (would get hub rings of course). The tires currently on em are 215/55/16, i think if i had the correct specs of the stock AWD i should be within about 1% rolling diameter. Assuming these will clear the stock brakes etc etc, anyone see any trouble running these for my winters?
#160
As for your question about staggered set ups and 20s
I'm running staggered on both my winter and summer set. As long as you keep the rolling diamater close to stock then you wont have any issues. Many of us have done it. View this thread https://www.clublexus.com/forums/is-...-mother-thread
Figure out exactly what size wheels you want what off sets it would help answer your question easier. This thread should help you get a better understanding https://www.clublexus.com/forums/is-...tart-here.html
Heres the wheel index members have posted their set ups on
https://www.clublexus.com/forums/is-...ead-index.html
And if you want to run a very aggressive set up view this thread
https://www.clublexus.com/forums/is-...el-thread.html
#164
varrstoen on my IS awd
Wondering if the Varrstoen ES 112
19x9.5
19x11
Would these fit on my 08 is awd, What tiires are recommended and if I can do 235/35/19 all around?
Thank you.
19x9.5
19x11
Thank you.
