Will those wheels fit? START HERE.
#3031
Have you heard of this company Avant Garde? Are they reputable?
And last but not least would these fit? I think i will need to run a spacer for the front?
The fronts are 20x9 (+34 offset) and the rears are 20x10 (+37), 245/35 up front and 275/30 in back
http://www.avantgardewheels.com/m310.php
those fit fine, but not with those tire sizes.
no spacers necessary.
#3036
Not going on a AWD, but will be going on my RWD
19x9.5 +35 Front (yes 19's)
20x10 +35 Rear (yes NOT 19's) I know it sounds weird.
245/35/19 tire front
285/30/20 tire rear
Fenders rolled and rear fenders will be pulled along with heating up and molding the fender liners on all 4 corners... Will I rub still? Keep in mind by fender pull in the rear we're talking about half an inch nothing more.
285/30/20 tire rear
#3039
285/30/20 tire rear
285/30/20 tire rear
#3042
Hi all,
I am getting some custom made concave five spokes and I need to know what offsets to tell them so they clear my calipers. Also would like to know what size tires to run.
I have a 06 IS350
H&R Springs
Fronts 19 x 8.5
Rears 19 x 10
many thanks this thread is priceless!
Here is what they look like: http://www.lomaforged.com/alloy%20cu...heel%20rsr.htm
I have a 06 IS350
H&R Springs
Fronts 19 x 8.5
Rears 19 x 10
#3043
Hi all,
I have a 06 IS350
H&R Springs
Fronts 19 x 8.5
Rears 19 x 10
I have a 06 IS350
H&R Springs
Fronts 19 x 8.5
Rears 19 x 10
but if given that those wheels will have caliper clearance with high (<40) and low (< 20) offsets, quickest and easiest way is to copy forgestar's specs for the 2is.
front = 19x8.5 +34, rear = 19x10+42. here's how it'll look:
https://www.clublexus.com/forums/whe...-f14-mint.html
#3044
ProjectDNA is right, very minor heat gun is needed at the back part of the front wheel well liner to prevent rubbing while turning (I did it already and the fronts are now cleared)
#3045
Then try 235/35/19 Front and 255/35/19 Rear for better wheel protection. I run this set up with 8.5+35Front and 9.5+36 Rear which is a little aggressive than yours and having no problem. 225/35/19 is ver skinny and has no side curb protection at all.
Thanx for the input....
i actually already placed an order on discout tire
225/35/19
255/35/19
now im thinking i should have ordered the 235 for the front... ill give them a call later to see if i can change my order....
