strange tpms problems! is350
Old 02-20-10, 07:48 AM
rselby
rselby's Avatar
Default strange tpms problems! is350
The check system light has been on for a lil while,showing a low tire( I just thought it was a bad TPMS sensor)...I know all the tires have like 35 psi in them..so had a friend scan the car..and it was showing a pressure reading in all 4 tires...and had some codes as well...C2121...C2122...C2123...so we erased them to see if they would come back...and they didnt...at least for a day or so..now the light is back on..anyone had any problems like this before? how can it show all 4 tires TPMS are working ..and then the light is on?
Old 02-20-10, 08:31 AM
ColtM4A3
ColtM4A3's Avatar
Did you check the pressure in the spare?
Old 02-20-10, 08:40 AM
AtlantaGuy
AtlantaGuy's Avatar
Did you check the tire pressure while each was COLD? What was the the psi for each? What year is your 350?
Spare doesn't have a tpms in it...
Old 02-20-10, 09:03 AM
rselby
rselby's Avatar
yep...was alil low..but filled it up..initalized it...still the same???, but good catch..thanks!...oh yeah that was a cold test on the psi and its an 07..and set the front cold to 36psi and the rear to cold 38psi..
Old 02-20-10, 07:33 PM
giantdefy
giantdefy's Avatar
After filling the tires with air, drive the vehicle, the TPMS warning should go away after a few minutes of driving.
Old 03-04-10, 03:07 PM
rselby
rselby's Avatar
the check system display is still on...and still get a reading from all TPMS?...anyway to reset...like pulling a fuse to the ecm/pcm or something???
Old 03-04-10, 04:34 PM
Kurtz
Kurtz's Avatar
Any chance you accidentally switched the car to look for the second (nonexistent in this case) TPMS set?
Old 03-04-10, 05:54 PM
rselby
rselby's Avatar
no..they are on the main set...any way to reset the TPMS computer...or whatever controls them?
Old 03-04-10, 08:54 PM
ISBU
ISBU's Avatar
The codes that you mention are trouble codes. There is no signal from your tpms. Here are the possibilities.
1. Tire pressure warning valve and transmitter
2. Tire pressure warning antenna
3. Tire pressure warning select switch
4. Tire pressure warning ECU and receiver
5. Wire harness or connector
Old 03-04-10, 11:04 PM
haulinick
haulinick's Avatar
i like to put the tires at the pressure that i want the warning to come on(about 30psi), initialize it, and THEN fill it to the pressure you want (I like 34-36). This way if your pressure goes down because of the temperature outside it won't be enough to trip ur tpms.
Old 06-20-12, 07:44 AM
LexoticJ
LexoticJ's Avatar
when it through those codes what was used to diagnose this?
Old 06-20-12, 08:14 AM
12369874's Avatar
is that you haven't program your new set of TPMS to your car's computer yet?
Old 06-20-12, 08:29 AM
LexoticJ
LexoticJ's Avatar
we have tried programming them at two different shops with two identical machines... problem is the ecu is not allowing the sensors to be programmed to the car... the sensors on my aftermarket wheels are straight from Sewell and I've had them on those wheels since september and never had this issue until after getting my car back from the dealership monday...
Old 06-21-12, 12:14 AM
12369874's Avatar
You pretty much HAVE to go back to the dealership to program it. Toyota dealership can do the same. Just my 0.02
GmanSC
01-23-19 06:14 PM
maarp
09-11-18 03:57 AM
zippinbye
GX - 1st Gen (2004-2009)
18
10-08-13 11:19 AM
Tensi
10-21-11 09:01 AM
brociouz
12-19-10 10:34 PM
Quick Reply: strange tpms problems! is350
