black grill
Old 01-11-10, 09:01 PM
tastfulmod
tastfulmod's Avatar
Default black grill
I am thinking of blacking out my front grill and the surrounding chrome of the windows but am not sure if I should get them painted or would black vinyle work just fine?
Old 01-11-10, 09:25 PM
xuningshen
xuningshen's Avatar
vinyl works great, Mv350 wrapped his and i think it looks great. not sure how its handle rocks and if its got any chips in it now though. i painted mine myself and it works too. so either or. personal preference
Old 01-11-10, 09:32 PM
tastfulmod
tastfulmod's Avatar
the only reason i would lean towards the vinyl is that if it does not work out i can redo it. how hard is it to remove the vinyl?
Old 01-11-10, 09:36 PM
xuningshen
xuningshen's Avatar
that is a great reason reason for going vinyl, i'm not sure how hard it is to remove but for sure its possible to remove.
if you can i'd go vinyl because painting you have to scuff up the chrome hella good for the paint to stick well, also when u want to get the paint off you have to sand. of course when you sand you ruin your chrome finish. so if u want to go back to stock you have to get a new one.
just take your time and do a good job so you don't have to overlap the vinyl on top of itself to cover it
Old 01-11-10, 10:21 PM
HeartmyIS
HeartmyIS's Avatar
I have my grill wrapped in vinyl, pretty easy and holds up well (the top two inner corners is probably the hardest to squeegee down correctly). Removing the vinyl is easy, just heat up a corner and peel. My friend just got the window trim on his e92 done, looks pretty good.
Old 01-11-10, 10:22 PM
cupid0210
cupid0210's Avatar
I would say vinyl i guess, I tried painting mine; had to take the grill off, sand it down, and then paint it black. Looked really nice the first month, but then with normal road conditions, the paint started to come off and it looked pretty tacky. I had to go to a Carbon fiber grill which I am MUCH more satisfied with. IDK how the vinyl would last though. I say go with CF!!! :-)
Old 01-11-10, 11:31 PM
Rash
hmm
Rash's Avatar
Heartmyis. You should take more pictures of your car. Truffle mica is hot!
Old 01-11-10, 11:51 PM
silverdust
silverdust's Avatar
looks good how much to do the grill
Old 01-12-10, 12:04 AM
HeartmyIS
HeartmyIS's Avatar
My friend did it for free. I can give you his number for his shop if you are interested, also does clear bras.
Old 01-12-10, 12:09 AM
HeartmyIS
HeartmyIS's Avatar
Thank you. IMO the color looks very much like SGM in pictures, unless I have a really good camera...pictures won't truly capture the color to it's fullest.
Old 01-12-10, 12:17 AM
teddyh2o
teddyh2o's Avatar
For vinyl, is it something that normal can do? or do i need to take it to a shop?
Old 01-12-10, 10:54 AM
HeartmyIS
HeartmyIS's Avatar
^If you have worked with vinyl it should be easy. It also depends on the type of vinyl you are using, the first type my friend used didn't stick too well to the chrome. If you do it yourself, take apart the whole grill bezel it makes it a lot easier and would be best to get a full wrap entirely around.
Old 01-12-10, 11:04 PM
duyl27
duyl27's Avatar
where to buy some vinyl in socal?
Old 01-12-10, 11:16 PM
ISThree
ISThree's Avatar
AeroTect
http://www.aerotect.net/Auto.html
Old 01-12-10, 11:30 PM
ISF4life
ISF4life's Avatar
do it once and do is right, sand it down and paint them yourself, just go to lexus and get a pint of watever color u want and do it, no vinyl stuffs will get chip rocks and will look bad... just keep in mind everything u want it to look professional or good it will take time to prep... preparation is the key to success !!!!
Quick Reply: black grill
