Better sound? New speakers w/ factory amp?
Old 12-15-09, 06:37 PM
farmrider
farmrider's Avatar
Default Better sound? New speakers w/ factory amp?
Hi
I have the non ML stereo. Has anyone gotten better sound by replacing the front speakers, but keeping the factory amp?
Does anyone know the specs on the factory amp, or front speakers?
THANK YOU
Old 12-16-09, 11:35 AM
josephdoc
josephdoc's Avatar
I dont think it will make a noticeable difference.
If you are looking for speaker specs, try Crutchfield's fitment guide.
Old 12-16-09, 11:52 AM
llamaboiz
llamaboiz's Avatar
just so you know, our spkrs are pioneer already, best way to improve sound would be to add a REAL sub box and remove the stock one (leaving the empty hole for a sound port).
Old 12-16-09, 02:10 PM
Mv350
Mv350's Avatar
you can o to component speakers, but like he said above. they are real pioneer speakers, meaning actual cones, not cheap@$$ paper cones. just wait until they blow/die
Old 12-17-09, 07:28 AM
dis250
dis250's Avatar
Someone on this forum said they changed their front speakers to dynaudio and noticed a improvement. I am with you and I think the factory system sucks *****.
Old 12-17-09, 07:57 AM
Mv350
Mv350's Avatar
you can go to focal components and you definetly hear a difference. Just look around and replace the tweeters and your woofer speaker(bottom of the door) and youll be set.
Old 12-17-09, 09:29 AM
joeker
joeker's Avatar
first of all, the non-ml package speakers aren't that bad.. they ARE cone speakers, meaning they are not made of paper. the only issue with installing new speakers is that the way lexus wired the car, makes it really hard to get a good sounding sound system for cheap. on the factory amp, there is three sections, one for highs, one for mids, and one for lows. your 6.5" speakers only play low range frequencies, your midwoofer only plays midrange frequencies with SOME high, and your tweeter plays only high range frequencies.. MEANING, if you want to upgrade you sound system, you cannot merely purchase a 6.5" component set, install 3/4" tweeters in the tweeter housing, and replace the 6.5" speakers. When you install a Hi to Lo convertor (LOC), splicing into your factory amp's 6.5" speaker harness, you will only pick up signals from the low end frequency. This will be a problem if you plan on using the crossovers. Other than that, if you want to buy individual speakers(non component), depending on your budget, you will notice a difference in sound quality. The only problem I had was that most companies don't make a 3/4" tweeter with great SQ, and most midrange woofers are at least 3"+, whereas our factory ones are 2.5".
jarm
06-19-10 10:47 PM
johnsc400
SC- 1st Gen (1992-2000)
12
08-21-02 12:50 AM
GS4SHO
04-18-02 07:50 PM
sisterkix
RX - 1st Gen (1999-2003)
03-24-02 12:24 PM
Quick Reply: Better sound? New speakers w/ factory amp?
