Upgrading to ML Nav in regular Nav equipped car?
Old 11-25-09, 12:23 PM
ScKcBc
ScKcBc's Avatar
Default Upgrading to ML Nav in regular Nav equipped car?
I have an 07, NON ML but does have NAV. Can I swap in an ML Nav setup for the option to watch dvd's?
Old 11-25-09, 06:05 PM
smpis350
smpis350's Avatar
From what I understand, the ML system needs upgraded speakers and uses 14 of them not the standard 13. It also uses a completely different amp system as well. I'm going to say yes you can swap it out to watch DVD's but then there is a good chance you will get error codes because of the missing ML hardware/software...
Old 11-25-09, 06:14 PM
kikaida
kikaida's Avatar
You will also need the digital cable that goes from the deck to the ML amp.
Old 11-26-09, 07:10 AM
350PsDMeuP
350PsDMeuP's Avatar
you can but finding that ML DVD unit is going to be pricey, you'll need the center speaker and sub along with the digital audio cable, I'm in the process of making one, and the amp. I can't remember if it was a different amp or not i was talking to someone that did the swap with the same amp, but maybe my memory serves me incorrect.
Old 11-26-09, 12:35 PM
Kurtz
Kurtz's Avatar
none of the stock speakers are the same as the ML ones...not even the same resistance...(and in the case of the rear ones not the same size or location on several of them)
I believe you can swap an ML dvd player into a regular nav, regular amp, car and get DVDs to play, but without surround sound.
linus73
11-06-11 07:42 PM
Playdrv4me
09-27-10 08:50 PM
English66
05-06-09 10:18 AM
Cut-Throat
10-22-06 06:01 PM
Quick Reply: Upgrading to ML Nav in regular Nav equipped car?
