strange smell
Old 05-25-09, 08:28 PM
jc86
jc86's Avatar
Default strange smell
when i turn on the AC in my car i get this disgusting smell that almost smells like urine... like it's disgusting... it's only recently begun to smell like this (since it became warm and i started using the AC)
could it be the cabin filter that needs to be replaced? or?
there's no smell when i'm not using the AC though and just the fan..
Old 05-25-09, 08:51 PM
Kevin350
Kevin350's Avatar
yeah its time to replace it.
Old 05-25-09, 08:58 PM
Little E
Little E's Avatar
All you have to do is turn off your A/C a few minutes before you turn off your car. This will prevent the fowl odor the next time you start your car and turn on the A/C. Don't leave your A/C running when you turn off your car.
Old 05-25-09, 09:17 PM
joeker
joeker's Avatar
can't you check under the maintenance menu?
Old 05-26-09, 06:09 AM
Bichon
Super Moderator
Bichon's Avatar
Changing the cabin filter is unlikely to resolve the situation, which is caused by mold and fungus on the evaporator core. Little E's suggestion is a good one, and often all that is needed. If that doesn't resolve the issue, have the dealer clean the evaporator core with a coil cleaner.
Old 05-26-09, 09:43 AM
Kevin350
Kevin350's Avatar
This is what I do. A mile b4 I get home I shut off AC and let outside air flow in. For 3 years, I haven't smell any urine odor. I also change cabin filter every 15k.
Old 05-26-09, 09:50 AM
kickin8
2IS/2RX/4RX
kickin8's Avatar
molds in the condenser....
Old 05-26-09, 10:43 AM
jayz250
jayz250's Avatar
How much is it to change out the cabin air filter by the dealer?
Old 05-26-09, 01:55 PM
jc86
jc86's Avatar
no idea but i'm going to check it out... car is still under warranty for another year so might as well bring it in to check it out. otherwise i may just drop by a canadian tire or something to find one
little e: thanks for the tip! i'll try it out tonight =)
Old 05-26-09, 01:57 PM
Kurtz
Kurtz's Avatar
Do it yourself- takes like 5 minutes in the glovebox.
Old 05-26-09, 02:19 PM
blk250
blk250's Avatar
time to change the filthy filter (goodluck)
Old 05-26-09, 07:06 PM
strife
strife's Avatar
Default Vent air smells like feet... =(
Hey guys...
The air from the vent started smelling like feet dipped in vinegar. I changed the cabin air filter today but the smell is still slapping my face.
Is there anything else I should check for?
Old 05-26-09, 07:07 PM
Bichon
Super Moderator
Bichon's Avatar
No, the condenser is by the radiator, if it were smelly only the engine would notice. The part that gets moldy is the evaporator.
Old 05-26-09, 11:15 PM
jc86
jc86's Avatar
i tried doing this today... it didn't really work at all. i also tried blasting the fan w/ out the A/C on and the smell was still there, just not as strong (for whatever reason)
btw - when you change your cabin filter what is this setting that it is suppose to be on? or else something will break? hmm?
Old 05-27-09, 04:21 AM
Kurtz
Kurtz's Avatar
Recirculate is what it needs to be on to avoid breaking stuff
Quick Reply: strange smell
