Warning message on Oil Filter
Old 12-15-08, 04:36 PM
Angela
Angela's Avatar
Default Warning message on Oil Filter
I just got my first oil change from Crown Lexus in Ontario, CA. A couple of days later, I see a warning message saying that I need to replace my oil filter? Is there a possibility that they didn't even change it, or do you think they just forgot to update the car on the maintenance that was done?
Also... my car has trouble locking (from using the button on the handle) and unlocking (from sensor) on the driver side but not from the passenger.... Anyone have this issue? Maybe it's just the battery?
-Angela
Old 12-15-08, 04:57 PM
slee18
slee18's Avatar
There isnt a message for the oil filter. They might have reset the oil maintenance light though. The owners manual shows you how to reset that. You should take in your car and have the handle looked at. It should work on one side and not the other side.
Old 12-15-08, 06:11 PM
Angela
Angela's Avatar
huh? what do you mean there isn't a message for the oil filter? it says to call lexus and it has a picture and says 'oil filter' on it..
Old 12-15-08, 06:22 PM
Bichon
Super Moderator
Bichon's Avatar
The built-in maintenance reminder is based on miles travelled. 5,000 miles after it was last reset, a bright orange exclamation point lights up and the words "OIL MAINT REQUIRED" appear on the small display between the tach and speedo.
Was the message you saw on that display, or on the nav screen? I seem to remember the option to set maintenance reminders on the navigation system calendar, perhaps that is what you are seeing?
Old 12-15-08, 06:29 PM
ISooNice
ISooNice's Avatar
maybe on her navi screen because i had no clue (if there was) a oil filter light. lol i think shes talking about her navi screen. just go to info, maintenance, and touch the reset button and voila
as for your door maybe it is your battery. sometimes mine doesnt open or lock either. but it works like a charm when i use my spare key sometimes
Old 12-15-08, 06:33 PM
Angela
Angela's Avatar
haha sorry, I meant my navi screen.. I should have been more specific.
I know that I can reset it myself, but I'm wondering if the dealer just didn't change it..... this happened to me when I had my rx8.. they would give it back to me saying that they did an oil change when they really didn't.. I'm wondering if maybe lexus didn't change my filter?!
Old 12-15-08, 06:34 PM
Evitzee
Evitzee's Avatar
There are about a dozen items you can be reminded about on the Nav screen; including oil and filter. Some are worthless, like rotation of tires on a RWD IS. You can block any and all of these on the Nav screen. This is probably what Angela is seeing.
Old 12-15-08, 11:24 PM
chris07is
chris07is's Avatar
take it back to the dealer, and ask them why did appear? ask them if they did really do a service... GD LCK
Old 12-16-08, 06:30 AM
Pnuge88
Pnuge88's Avatar
^ agreed. theres no way of telling unless you take out the filter and see how dirty it is... i use to work at lexus and i tell you theres one guy who burns this stuff.. only drains the oil and not the filter. so be careful. just one question. when i do an oil change. usually we leave the oil filter reminder alone.. so maybe thats what the tech did. was your oil maint reset though? that could be possible as well. you should get it checked to make sure.
Old 12-16-08, 08:45 AM
slee18
slee18's Avatar
I see the blind man said. I dont have NAV so i didnt know that!
Old 12-16-08, 09:05 AM
nehal51086
nehal51086's Avatar
Originally Posted by M1sTa801
^ when i do an oil change. usually we leave the oil filter reminder alone.. so maybe thats what the tech did.
the techs at hendrick lexus never set the reminder in the navi...i always do it my self before leaving the dealership...
Old 12-16-08, 11:17 AM
RA030724
RA030724's Avatar
As far as the door handle, you have to have the key in your pocket obviously, but I have found you must grip the door handle with all fingers especially in the winter. I assume the proximity detector detects the body mass/heat of your hand and it is harder to do when cold. I know in the summer I just have to put a couple of fingers behind the handle and it quickly opens. In the winter I need to wrap all four fingers around the handle. Never tried it with gloves, so not sure if they make a difference also.
Old 12-16-08, 12:49 PM
kickin8
2IS/2RX/4RX
kickin8's Avatar
just reset the reminder and call it a day.....?
Old 12-17-08, 06:11 AM
Angela
Angela's Avatar
Yes, the oil maintenance was reset, but not the oil filter. I guess I should ask them.. but even if they didn't change it, they wouldn't admit to it. Oh well.. I guess I should start doing my own oil changes from now on.
Old 12-17-08, 06:17 AM
Angela
Angela's Avatar
That's good info.. Thanks. I just realized the times it didn't work, it was pretty cold outside.
Quick Reply: Warning message on Oil Filter
