This may be a dumb ? (TPMS battery)
Old 10-09-07, 10:44 AM
dan206
dan206's Avatar
Originally Posted by Gernby
I don't see this working very well. If one sensor is bad, the TPMS computer will simply report a problem. I don't think the computer tells how many problems there are, just that there is at least one problem. How could you do any elimination at all if the computer never tells you anything different?
If one is bad it doesn't say what is bad did you read what I said??? They inflated and deflated the tires the one that is not working will not read the tire pressure back to the computer. That is how they find out what one is not working..... Its not the most technical way but sure does do the trick and that is how my dealer did it without dismounting them all but feel free to take each one out of if you want. Also this is not reading from the dash board its the dealers computer they plug into the dash of the car....
Old 10-09-07, 11:11 AM
Gernby
Gernby's Avatar
I didn't notice your comment about the "dealer's computer". I thought you were saying that this method would work for anyone with a TPMS problem. Personally, I would never go to the dealer for anything that wasn't going to be covered by warranty.
Old 10-09-07, 12:10 PM
dan206
dan206's Avatar
Yeah of course but when The Tire company is paying for it I could care less I don't care how much it costs them as long as my car is working the way it was before they effed it up.
Old 12-20-10, 05:16 PM
iGS430
iGS430's Avatar
Screw TPMS, how about the old check your tire pressure weekly on your next gas fill up. Its not like the vehicle is going to automatically re_inflate the tires to spec like military vehicles equipped with CTIS (Central Tire Inflation System) That's another million dollar idea....Hint Hint.
Old 12-20-10, 05:53 PM
brociouz
Uber 1337 Moderator
brociouz's Avatar
Epic thread bump. FYI: The TPMS battery is sealed inside the sensor assembly with some kind of foam-like surround. It is definitely not easily changed.
Old 04-26-17, 02:54 PM
samsonn25
samsonn25's Avatar
Like changing the glued in power supple diodes on the Mark Levinson Amps
Old 04-26-17, 07:23 PM
flowrider
flowrider's Avatar
Received 1,831 Likes on 1,293 Posts
The TPMS battery is not replaceable - period! The battery life is AIRC, 5 to 7 years. You replace the whole unit.
Lou
waltsox
ES - 6th Gen (2013-2018)
08-02-16 01:23 PM
ThumperPup
ES - 5th Gen (2007-2012)
04-01-15 09:23 PM
GQis350
08-26-12 08:35 PM
swooopeno
03-02-11 08:34 AM
AWDGS300
08-19-10 10:29 AM
Quick Reply: This may be a dumb ? (TPMS battery)
