steering column buzzing
Old 08-02-07, 12:44 AM
gshb
gshb's Avatar
Default steering column buzzing
hey guys, so i have a buzzing in my steering column that sounds like metallic in nature. it usually occurs at 20mph and 50mph. i already opened it up and tried to fix it but i cant seem to find the source. if you push up on the column shroud, it stops the buzz. does anyone have any experience?
Old 08-02-07, 12:59 PM
iceman1117
iceman1117's Avatar
I get the same noise but when I start the car. Its weird because it only does it sometimes.
Old 08-02-07, 01:14 PM
Bichon
Super Moderator
Senior Moderator
Bichon's Avatar
The noise when you start the car is the steering column lock disengaging.
Old 08-02-07, 02:57 PM
iceman1117
iceman1117's Avatar
That never crossed my mind but it sounds that could be it. Thanks. Does it to also do it to your car sometimes?
Old 08-02-07, 03:32 PM
ben_r_
ben_r_'s Avatar
If it persists and you cant fix/find it, Id take it in...
Old 08-02-07, 06:32 PM
PNice972
PNice972's Avatar
i had this same problem, took it in to the dealer and they had to replace the whole steering column, funny thing was, the noise is back. i've just learned to live with it now
Old 08-02-07, 06:51 PM
gshb
gshb's Avatar
ah ic, well i put in a whole bunch of foam in there and it definitely helps. its just instead of being constant its intermittent and only on the roughest roads.
Old 08-02-07, 09:52 PM
iceman1117
iceman1117's Avatar
I took apart my intake today and replaced the old coupling that holds the intake to the throttle body just to make sure that the T.B. and the intake wasn't causing any friction with one another which is leading to the rattleling. I just wanted to make sure the intake has nothing to do with the rattleling before I take it in and the dealer try’s to give me a hard time about it. Like I said in the previous post, it only does it sometimes so if it does it again I am taking it in for sure.
Gshb, in your case it only does it around 50mph and over bumps. Next time you start up your car see if by any chance it also does it. If you take your car to the dealer before I do let me know what they tell you. I will also do the same if I go in before you.
2008GS
04-28-17 08:25 AM
tomstep2
RX - 1st Gen (1999-2003)
21
03-01-14 04:36 PM
Stevoe88
05-05-13 07:12 PM
kevsES330
12-03-08 08:31 AM
caha14
GX - 1st Gen (2003-2009)
16
05-12-05 06:25 PM
Quick Reply: steering column buzzing
