Old 12-15-14, 01:10 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
DIY aftermarket amp power wire install step by step with pictures
Old 02-10-11, 06:20 AM
  #91
Supernin
Supernin's Avatar
Originally Posted by drummerjim
Supernin did you ever figure out what happened?
It was a fuse that blew, which of course is what I suspected right off the bat. But there is a third fuse panel that I failed to check, under the passenger door, and it had a blown fuse. So it's all good. Amp/sub installed, plus USA Spec TOY adapter for iPhone and bluetooth hack.
Old 02-20-11, 01:48 PM
  #92
Alex2422
Alex2422's Avatar
Hey first time doing this so sorry if I did something wrong when posting. Just put in a 4 channel amp with a mono Jl amp plus bass **** to my Stock Nav unit (IS250 2007). Used Jl clean sweep/ summing device which might have been a little much for the price but was worth it. Worked perfect and sounds great before after market speakers and even better after I swithced them out. Was wondering if anyone put in after marker midrange speakers I cant find any that will work? These will blow soon with the way im playing them..
Old 02-20-11, 03:22 PM
  #93
Slammer1
Slammer1's Avatar
The mids in the doors are roughly 2.8" speakers. I am not aware of anyone who makes them aftermarket. When I changed mine, I used component speakers, with adapters that allowed me to mount my tweeters in the opening that used to hold the mids. The factory tweeters are still in thier mounts at the tops of the doors, but are not connected and do not play.
Old 02-20-11, 06:48 PM
  #94
Alex2422
Alex2422's Avatar
Thanks ya I put in new Tweeters in all the doors but wanted to keep all the speakers some how. I saw someone put in 3-1/2in Focals in the mid spot. Looked great but to get those I would have to buy the 3 speaker set which is over a grand a pair. So looking at cheaper 3.5in speakers now not sure if someone did this yet..
Old 02-21-11, 05:15 AM
  #95
Slammer1
Slammer1's Avatar
I haven't seen it, but I'm sure someone has done it that way before.
Old 03-17-11, 08:02 PM
  #96
kneepuck
kneepuck's Avatar
anyone set their gain using a 50hz 0db test tone? if so, how did you avoid running the 0db test tone through your factory speakers while trying to set the gain for the subwoofer? i know its bad to send a 0db test tone through speakers, but if the amp is connected to the factory ML system's signal, how did you avoid letting the 0db tone go to the other speakers?
Old 03-20-11, 12:40 AM
  #97
sushiboi
sushiboi's Avatar
Does anyone know if I can combine the signals from the L and R front woofers and signals from the stock sub straight into a 2-channel LOC? I already bought it prior to finding this post..
Old 03-20-11, 01:06 AM
  #98
jnguyen87
jnguyen87's Avatar
i think you need a 4 channel LOC
Old 04-05-11, 10:29 PM
  #99
sushiboi
sushiboi's Avatar
I have a 2-channel LOC, and I was thinking about connecting it to both channels of the sub on my non-ML. Any suggestions.. Do's or dont's?
Old 04-06-11, 06:02 AM
  #100
Supernin
Supernin's Avatar
It's really your only decent option. Several folks, including me, have tried using some other speaker connections and it never works out as well.
I will say this: access the wires as they leave the amp, in the trunk, rather than trying to remove them from the sub itself and then running them to your LOC. I did that and it is a huge pain in the *** trying to access the sub under the rear deck. Just leave it there, leave it connected to the wires, but cut the wires at the amp site. That way it's just a quick splice if you ever want to go back to stock.
Old 04-12-11, 06:04 AM
  #101
Likwid XTC
Likwid XTC's Avatar
Great post helped answer a lot of questions I had I'll attempt to do the install in a few weeks
Old 04-16-11, 10:36 PM
  #102
lilmanrock
lilmanrock's Avatar
Printed out initial DIY from forum and had shop install. Works and sounds great!!!
Old 04-25-11, 11:52 PM
  #103
doghouse
doghouse's Avatar
Default ??
Originally Posted by tt061880
here are the pictures
the Scosche LOC I used, got it from Wally World for $17.99, with 90 return policy LOL
the ML location, rear corner on passenger side
subwoofer wires to tap from, BROWN(+) and LIME GREEN(-), the NON ML version has two pairs, BROWN & LIME GREEN and PINK(+) SKY BLUE(-)
right front woofer, PINK(-) and BROWN(+)
left front woofer, RED(-)and WHITE(+)
remote wire, it's the last PINK wire farthest to the back
after everything is in place
time to set the gain, I went below the JL recommendation, around 35v. They recommened 38v for best result, no clipping. Here's the link to the instruction http://mobile.jlaudio.com/support_pages.php?page_id=143
and DONE!
hello do you know if this amp wiring diagram is the same for a 2006 gs300?
Old 05-01-11, 01:45 AM
  #104
PeneAce
PeneAce's Avatar
This is great, I'll definitely do this!
Old 06-01-11, 01:55 PM
  #105
sushiboi
sushiboi's Avatar
I tried pulling up on my backseat to remove it, and I heard some cracking? Is this normal? Last thing I wanna do is snap my backseat in half.
Quick Reply: DIY aftermarket amp power wire install step by step with pictures
