Anyone Else's Navigation Reset?
Old 03-09-07, 12:51 PM
OutlawsX
OutlawsX's Avatar
Default Anyone Else's Navigation Reset?
My 06 IS350's navigation would reset once in awhile.. usually after I restart the car. All my presets are erased, and I have to set everything back up... has this happened to anyone else? How did you resolve this? Should I take it in for checkup or did I do something wrong?
Note: It seems like it happens after I do the Override trick, then shut down the car, come back later, and the system is reset.
Old 03-09-07, 02:43 PM
tt061880
tt061880's Avatar
i've done the override trick many times and that never happened to me
Old 03-09-07, 03:25 PM
iainthim
iainthim's Avatar
Sometimes mine has me positioned in the middle of the ocean. Not sure how or why it gets so far off but i have had to recalibrate it several times.
Old 03-09-07, 03:28 PM
viettho
viettho's Avatar
There is TSB for your navi pointing in the middle of the ocean. I just had my dealer replaced new disc for me.
Old 03-09-07, 04:38 PM
OutlawsX
OutlawsX's Avatar
So no one else's Navigation resets? Next service, I gotta bring it up to tech.
Old 03-09-07, 05:28 PM
TimboIS
Liquid Bra Champion
TimboIS's Avatar
And he'll tell you not to f*** with it.
Old 03-09-07, 06:14 PM
lobuxracer
Tech Info Resource
Senior Moderator
lobuxracer's Avatar
Received 4,078 Likes on 2,471 Posts
I use the nav override feature frequently. I've never had what you described unless I pulled the TV1 fuse. That reset EVERYTHING.
Old 09-24-07, 04:51 PM
OutlawsX
OutlawsX's Avatar
Well today the Navigation reset twice. I simply go into my car (82 degrees) outside, and when the screen is suppose to come on.. it resets. Loose fuse somewhere?
This usually happens when it's a hot day. Hmmm... It's more annoying than anything else.
Old 09-24-07, 05:52 PM
nighthawk
nighthawk's Avatar
only if you go in they will give you the updated nav disk and you won't be able to do the override thing
Old 09-24-07, 08:46 PM
ecr527
ecr527's Avatar
Same thing happened to me while I was on a trip. They replaced my nav disc under the TSIB and it fixed the problem.
Old 10-31-07, 09:27 AM
OutlawsX
OutlawsX's Avatar
I have to get my Nav disc changed today ... it's resetting nearly everytime I start my car. It's getting really annoying.
Old 01-07-08, 09:32 PM
whitels
whitels's Avatar
Curious what version disc was causing all these problems? And what version fixed it?
Old 01-08-08, 07:11 AM
Salil022
Salil022's Avatar
something strange happened to my 06 IS350 navi last week, i had destination set and all of a sudden while i am at traffic light, first audio turned off by itself and all i see on the screen was AUDIO OFF and then i tried to turn power on for Audio nothing happend and then screen went off, all i could see on the screen was "CHECK SYSTEM" Everything went off on the NAVI and tried pushing all the buttons, no luck....i pretty much got frustrated and turned the car off and on and everything back to normal....Has this happened to anyone before???
Old 01-08-08, 01:51 PM
OutlawsX
OutlawsX's Avatar
Everything is fixed now... first Westminster Lexus did a new Disc swap... but that didn't resolve the issue, it made it happen more often. Then I went back and they fixed it with a new Nav unit. It was buggy as heck.
Old 01-08-08, 04:08 PM
AsianGirl007
Lexus Diva
AsianGirl007's Avatar
Any update on that weird grinding noise coming from the front end? That didn't sound right at the holiday meet.....
Quick Reply: Anyone Else's Navigation Reset?
