transmission fluid
#31
i went to lexus the other day and they stated that these transmisions are serviceable..........they even recommended that the transmissions should be serviced around 30k miles and i also have a friend that's a master tech at toyota telling me that it should be serviced at around 50k...........my car is almost at 30k, so when i get it serviced hopefully i'll be able to get some pics to show
#32
If the car was put on a lift with the back wheels left to spin with the engine running and in gear, then it seems like most of the tranny fluid could be changed by pumping fresh fluid into the oul pan's drain plug while the excess (mostly old) fluid spills out the "fill bolt". If it could be done, then pumping 8 qts through would change about 75% of the fluid.
#33
Lemme guess, you have a manual 250?
#35
I'm still confused why people want to service something that says is not serviceable in the manual. You could also change out your light bulbs every 30k but why on earth would you do that when they can last you over 100k?Then at the same time other people say that you dont need a 5k oil change and that 7.5k or 10k is sufficient.
I believe that some dealers will charge you for anything you ask for. Do my brakes need changing? Yea they have about 50% left, we'd recommend you get new pads, rotors, shim kit, and an alignment. We can also flush your coolant, and clean out your roller bearings. Grand total: $1500
I'm going to roll with what the manual says, I trust Lexus, their ingenuity, and their reliability more than any other mfg. Not messing with the tranny, but I will change oil every 5k miles.
#36
For the record, the transmission fluid is good for at least 100,000 miles (automatic)
Not saying this is you but why is it so many people (in America) think the manufacturer's recommendation are wrong and go ahead and waste their money on useless maintenance...oil changes especially come to mind. Our European friends seem to be so much better informed than most of us here on what is truly needed as far as maintenence is concerned....
NO moderator.......I'm not trying to start an argument!
rueshan (02-25-23)
#38
#39
Just curious here. Did you read your owner's manuel? Assuming you did not based on your question perhaps you might want to take some time and do so.
and also, im not trying to start an arguement
#41
I'm going to change my auto tranny fluid on my 2IS at around 45k with oem Toyota fluid. When I do I will post pics of how to do it. Yes the tranny is serviceable. And there is no such thing as lifetime fluid. My dad has a shop and I will do it there.
#43
I'm sure there is. Once you drop the oil pan then it will be exposed. Usually they are a metal screen type so you dont need to buy a new one from the dealer. You can just rinse it out. A new filter will cost $60+. Not worth it.
#44
Tech Info Resource
You might want to look at this before assuming anything about this gearbox. See the filter info at the bottom too.
