Accessing the back of the NAV console.
Old 12-31-05, 08:18 AM
  #31
Payam
Payam's Avatar
Ok, is the white wire with the silver on it that you have to cut on the little 24 pin plug directly next to the J50? If so where do you have to cut it and what do you need to do to it? because on the plug closest to the passenger side there is only one white wire and it doesn't have any silver on it. But the little plug that is in the middle has a little white wire with silver on it in the #4 hole not #16 which someone said earlier. Thanks.
Old 12-31-05, 08:52 AM
  #32
tim817
tim817's Avatar
The white wire is on the P1 connector. As you see from my pic, it should located on the far left at the bottom of the P1 connector. here is the DIY link: https://www.clublexus.com/forums/sho...d.php?t=193739
Old 12-31-05, 01:50 PM
  #33
Payam
Payam's Avatar
Thanks. Your the man.
Old 01-30-06, 08:06 AM
  #34
bobgott
bobgott's Avatar
Cool
Originally Posted by muzzman1
I finally made the time to do this mod...I was assured by my service manager that if I killed any components in my unit he would warranty....with that said I pulled my unit out, took the speed sensor wire off the multi display, cut it and the white (silver banded) wire on the NAV ECU an bypassed the multi display so it no longer recieves a speed signal...the NAV works PERFECT not jumpy.....I can now dial the phone while driving, the #'s show up on the speed dial, Caller ID shows when moving!!! The phone book is now also visible....sorry no pics....I did it at a friends shop an did not have my camera....
So does this also override the the GPS functions that are locked while driving (like entering an address, etc)?????
Thanx...
-bob a new IS 350 owner
Old 01-30-06, 08:31 AM
  #35
Bichon
Super Moderator
Senior Moderator
Bichon's Avatar
Thanx...
No, if you bypass the speed input to the nav unit then map updates become jumpy. So you'll have to do the software override (which unfortunately resets every time you turn off the car) to access navi functions while driving.
Old 01-30-06, 09:23 AM
  #36
bobgott
bobgott's Avatar
Well ... what I wanted to hear was, there is an override which takes care of it permanently .. guess you can't always get what you want.
Can you be so kind as to reply with the link on how to do the software override??
thanx ..
Old 01-30-06, 11:17 AM
  #37
Bichon
Super Moderator
Senior Moderator
Bichon's Avatar
thanx ..
Certainly. http://wiki.ehow.com/Override-Lexus-...on-Motion-Lock
Old 02-01-06, 07:18 AM
  #38
bobgott
bobgott's Avatar
It worked! .. thanx a bunch.
-bob
Old 03-11-06, 04:19 PM
  #39
gmeardi
gmeardi's Avatar
Default 'Safe' E-Brake mod? (no speed...)
I imagined that disabling speed input to the nav could give problems (even because I knew that often the best car nav systems use the car speed values to adjust / continue to assess the vehicle position when you r not under satellite coverage - ie in a gallery). But... could the trick explained in advance to ONLY disable the 'parking brake' control (E-brake mod) allow to watch DVD movies on the run without giving any functionality problems? (for kids and with care, of course...)
Many thanks,
Gianluca
Old 10-02-06, 01:40 PM
  #40
tcc202
tcc202's Avatar
I am looking to pay for this to be done. I am southern CA. south of LA
tcaptanis@yahoo.com
Old 03-10-07, 04:58 PM
  #41
thatsdeux
thatsdeux's Avatar
hi
well i did it exactly how it was shown, but i is there a way to get that e-brake sign off?
Old 08-10-11, 01:06 PM
  #42
abs0lute
abs0lute's Avatar
So if you just want to do the rolling dvd with the ML version, all you have to do is ground that red wire on the is350?
Old 08-13-12, 11:30 AM
  #43
g15e22
g15e22's Avatar
Default 07 IS350 Navigation Override
Some one please Help, I have 07 IS350 with ML. I cut the Light pink wire on Connector J50 and the White with Silver on connector P1. Exactly how it show on "https://www.clublexus.com/forums/is-second-generation/193739-navigation-hack-diy-part-one-enable-dvd-phonebook-and-mp3-folder-while-moving.html". I also Ground the red cable on connector j50. I now have the light on my dash for the ebrake on and when Im driving I am not able to enter an address. So this didn't work for me. Is there a second speed wire.
Old 08-14-12, 12:42 AM
  #44
ISCjonny
ISCjonny's Avatar
did you connect them together after you cut them?
Old 08-14-12, 08:00 AM
  #45
g15e22
g15e22's Avatar
I did just like in the picture. I connected the white with silver wire with the light pink wire. Also since I ground the Red wire is the brake light always going to stay on.
steverhode
12-01-15 03:07 PM
ECL
08-21-15 07:57 PM
Lexus GS3
02-15-11 09:30 PM
Barefoot B
03-10-09 07:53 PM
vipermann1
03-26-02 10:03 PM
Quick Reply: Accessing the back of the NAV console.
