Those look nice. would it be possible to just get white lights instead of installing the HID kit, i no it doesnt make it HID but its almost there and about 1/10th the price.
No because HID bulbs run at a completely different wattage, and they are way different in terms of fit as well. The HID bulbs don't use a filament like the regular halogen bulbs do. An HID bulb needs to be ignited, and a halogen bulb needs to be switched on.
yes i know, they have things called Super white or something like that, you just replace your OEM bulbs with those, would those work? what are the numbers of the bulbs? H11 and 9004?
the low beam is H11--there are various makes of super white bulbs. The high beam/DRL is 9004, which will be easy to find. I don't recomment usinig a high-wattage halogen bulb because most of them burn out frequently, not to mention the wiring harness may be damaged after prolonged use.
aight so in otherwords, either put the HID kit in or leave the stock lights?
In terms of brightness, oem is best since the assembly is designed for it, and you get auto-leveling and AFS. HID kit is next on cost and effectiveness. Blue bulbs give OTHERS the impression of HID but is not brighter unless you go with higher wattage (which has shorter lifespan and the risk of overheating). I haven't used high wattage bulbs for 7-8 years, so I can't speak for their quality nowadays.
