IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
02 IS 300 Codes
Old 06-19-14, 08:00 AM
Exia
Exia's Avatar
Default 02 IS 300 Codes
I had to codes come up today on the car P0141 and P0306
I was wondering since code P0141 might have anything to do with P0306, cause apparently that O2 sensor somewhat runs in conjunction with Cylinders 4,5,6. and P0306 is Cylinder 6 misfire..
Car runs pretty good, and doesn't miss.
Old 10-05-14, 09:04 PM
Schmitt605
Schmitt605's Avatar
p0141 o2 sensor fault- possible replacement needed for your o2 sensor. how many miles do you have? and on your p0306 cyl 6 misfire- have you hooked up a good scan tool with live data to check for misfires? even tho it seems to run good it could have an occasional misfire on cyl 6 that wouldnt be too noticeable. id check that first to see whats going on and go from there
ManuelFdz
12-27-21 04:25 PM
5t341th
Maintenance
12
12-16-17 03:23 PM
RSpi
03-19-17 03:52 PM
Cabral255
RX - 1st Gen (1999-2003)
12-18-12 07:08 AM
Charlie088
01-29-12 04:13 PM
Quick Reply: 02 IS 300 Codes
