IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
1-piece driveshaft
Old 03-16-13, 10:40 PM
NoMoreVTEC
NoMoreVTEC's Avatar
Default 1-piece driveshaft
Anyone have a 1-piece driveshaft on their IS? I was thinking about ordering one (probably aluminum) this week from the driveshaft shop.
If you do, what were the dimensions you measured? I've got an Auto trans and just wanted another measurement to compare with.
Also, anyone know if the supra has the same trans as the IS? Sorry if these seem like stupid questions. I'm just new to the IS supra, gs...2jz and would like to find out more.
Old 03-17-13, 04:40 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
um, we already have 1 piece driveshafts...
Supra Auto transmissions are a340e's, IS auto trans' are a650e... difference - power handling and Supra's are 4 speed, IS are 5 speed autos...
Old 03-17-13, 07:07 PM
NoMoreVTEC
NoMoreVTEC's Avatar
We do? I was under the impression the IS300 A650e trans had the carrier bearing (much like many RWD vehicles)? I haven't looked for myself I was just doing some research before tore into it. I'll be sure to check it out tomorrow.
Old 03-17-13, 11:50 PM
NoMoreVTEC
NoMoreVTEC's Avatar
isn't this the factory drive shaft for an IS?
http://www.ebay.com/itm/01-02-03-04-05-LEXUS-IS300-REAR-DRIVE-SHAFT-AUTO-TRANSMISSION-OEM-/190804542462?pt=Motors_Car_Truck_Parts_Accessories&hash=item2c6cd643fe&vxp=mtr
I was thinking this was a 2-piece design where as one from HPF or driveshaft shop would be a 1-piece.
Old 03-22-13, 11:14 AM
1Gis300
1Gis300's Avatar
^^^ that is a Auto Drive shaft and they do come in 2 piece i haven't seen a OEM 1 piece but i could be wrong. I just did a Manual swap and install a 1 piece shaft. it feels more aggressive to me. experiences very though
Old 03-22-13, 09:29 PM
mitsuguy
mitsuguy's Avatar
Hmm, could be wrong, coulda swore it was one piece under there, never paid that much attention (and I've had the motor/trans out twice) to be honest... way better ways to improve performance for that kind of money... I focus on engine and electronics (turbo and standalone)...
Old 03-23-13, 09:42 PM
BoughtanIS
BoughtanIS's Avatar
Would a Supra/SC300 W58 driveshaft fit our W55s..?
Old 03-23-13, 10:09 PM
mitsuguy
mitsuguy's Avatar
Hold on... you did a manual swap and at the same time installed a 1 piece shaft, and attribute the aggressive feeling to the driveshaft and not the transmission???
Old 03-24-13, 04:22 PM
Meowmr2
Meowmr2's Avatar
On my Manual IS300 its a two piece drive shaft.
Old 03-25-13, 04:52 PM
1Gis300
1Gis300's Avatar
I think 1 pice drive shaft even on auto will make your car feel a little bit more aggressive.
Because u don't loose as much power or torque like a 2 pice shaft.
Old 03-25-13, 08:41 PM
Kickrock
Kickrock's Avatar
yea he needs to double check his tranny
Old 03-25-13, 08:44 PM
mitsuguy
mitsuguy's Avatar
lets say a stock IS300 makes 220 hp from the factory at the crank... now, lets say we have a 18% drivetrain loss, which is 40hp... Even if you could reduce drivetrain loss by 25%, you would only be getting back 10hp from the installation of a one piece driveshaft... Most of drivetrain loss is friction anyways, not weight...
What does a one piece driveshaft cost? there are a lot better ways to spend that money, IMO, but to each their own...
Old 04-07-13, 01:00 AM
NoMoreVTEC
NoMoreVTEC's Avatar
You know you're absolutely right about the power gains/$ ratio. I'm just modifying certain areas of the car first to not affect the quality of the ride too drastically right now. I've got 3 semesters left of college then I can begin the real fun of modifying and toying around with forced induction. As of right now, I'm just trying to prepare the chassis suspension & drive train to make the ride a little more enjoyable. Not saying it's not enjoyable now of course, I'm conducting a little investigation of my own as well. So you could say this inquiry for the dimensions of the 1-piece for "research"
Old 04-11-13, 05:21 PM
ais300c
ais300c's Avatar
dezod has one peice driveshafts for our cars, dezodmotorsports.com I am getting one from them to get rid of that two piece crap
Old 09-28-20, 02:32 AM
Seongupark
Seongupark's Avatar
where did you get yours and what measurements did you use?
Quick Reply: 1-piece driveshaft
