IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
W58 swap help
Old 02-27-13, 10:31 AM
hyboostIS
hyboostIS's Avatar
Default W58 swap help
Hi Everyone,
I have searched and can not find a actual answer to my question. Which is if i swap a W58 in to my IS with is auto right now. Do i have to find a W55 to swap housings or can i just put the
W58 in and its a little long or short?
Also which flywheel and clutch do i have to use?
Like i said i searched and cant find apost or person said you need this and thats it.
Thanks For your guys help
Heres some pics of the Wagon
Old 02-27-13, 10:37 AM
exist3nce
exist3nce's Avatar
I recently did a W58 swap myself, but I was swapping from a W55. I can tell you that you will need the bellhousing from the W55 to make the transmission the correct length. Also you will need the tail-housing / shifter assembly from the W55 as well. As for clutch setup, I'd suggest to go with the MKIV Supra N/A clutch setup. So you need the flywheel, flywheel bolts, clutch kit (disc and PP). I think the W55/W58 throwout levers are the same, but I just used my W55 one. Also you will need an 80mm pushrod for the slave cylinder.
If you haven't already, go and search on my.is as well.
Old 02-27-13, 10:55 AM
1Gis300
1Gis300's Avatar
i just did this swap to my 01 Auto and i use the w58 bell housing and simply cut and welded the fork that holds the shifter to make it sit center and i did a custom 1 piece drive shaft. i put it to gather on a 1,100 budget.
[IMG][/IMG]
Old 02-27-13, 11:34 AM
hyboostIS
hyboostIS's Avatar
Thanks for the info. If i dont have the W55 to swap parts with how far off is the W58 and in which direction
Old 02-27-13, 11:36 AM
hyboostIS
hyboostIS's Avatar
1Gis300
Do you have any pics of the part u welded? what clutch and flywheel set up did you use?
Old 02-27-13, 03:12 PM
1Gis300
1Gis300's Avatar
I really didn't take much pics sorry here is the only pic I found u can see how it was cut and welded on top.
[/IMG]
I used a MKV NA supra flywheel and sc300 clutch kit I used a 6puck clutch it's its has a stock pedal feel to it Surprisingly. Lol
[/IMG]
Old 02-27-13, 03:13 PM
1Gis300
1Gis300's Avatar
[IMG][/IMG]
Old 02-27-13, 03:14 PM
1Gis300
1Gis300's Avatar
[IMG][/IMG]
Old 02-27-13, 03:15 PM
1Gis300
1Gis300's Avatar
I haven't had any shifting problems Whatsoever really smith and solid and ill be beating the gears se time. Lol
Old 02-28-13, 07:44 AM
exist3nce
exist3nce's Avatar
Ya I guess it can be done that way too
Old 02-28-13, 08:40 AM
AZTurbo
AZTurbo's Avatar
Keep in mind that the tripod is only on the W58 from the NA Supra or later model SC300 like 1Gis300 has so this modification may not work on earlier SC300 W58's, therefore requiring the W55 rear housing and driveshaft.
Old 03-01-13, 05:02 AM
hyboostIS
hyboostIS's Avatar
So if i get one that looks like R154 tailshaft housing it will be to long and cant be modified is what your saying?
Old 03-01-13, 07:38 AM
AZTurbo
AZTurbo's Avatar
At that point you may need to find a W55 tailpiece and swap it out.
jimmymac30
SC400 / 300 Classifieds
04-03-18 02:43 PM
drastiq619
Performance & Maintenance
10-19-14 08:04 PM
joezhu110
Performance
01-20-14 03:39 PM
crenfro
08-15-13 08:43 AM
lowkeySC
12
08-27-09 09:05 PM
Quick Reply: W58 swap help
